socket to send a huge array of int from ESP32 to Linux Python Socket server
Hi all.
I’m trying to build 2 codes.
1 socket client on the ESP32 dev board to send an array of 700 numbers ( int(2) ) to a linux python server
My code works well with strings but I do not know how to modify is to send this array instead of string
Python side
import socket
s = socket.socket()
s.bind(('0.0.0.0', 8090 ))
s.listen(0)
count=0;
while True:
    client, addr = s.accept()
    while True:
        content = client.recv(4096)
        content = content.decode('utf-8')
        if len(content) ==0:
           break
        else:
            print(content)
    count=count+1
    print("Streamed IMG:" + str(count))
    client.close()
ESP32 side
#include <WiFi.h>
const char* ssid = "ssid_network";
const char* password = "password";
const uint16_t port = 8090;
const char * host = "192.168.128.xxx";
  WiFi.begin(ssid, password);
    Serial.println("...");
  Serial.print("WiFi connected with IP: ");
    WiFiClient client;
    if (!client.connect(host, port)) {
        Serial.println("Connection to host failed");
        return;
    Serial.println("Connected to server successful!");
    client.print("tagada");
    Serial.println("Disconnecting...");
    client.stop();
How do I modify the code in python to receive the array and in the ESP32 code to send the array ?
