SODAQ ONE, sleeping and waking the accelerometer
Hello everyone,
I am currently trying to do something which seems like it should not be very difficult. I have a SODAQ ONE version 2 board using the LIS3DE Accelerometer. Here is a link.
The problem is, I am very new to the whole world of sensors, and my programming skills with Arduino up until I have started this project are zero.
The code I am using does following: prints the Z axis every second to the serial debug, and if you move the board it prints “On-the-Move is triggered” to the serial debug. This is great, but when I try to put it to sleep it goes to sleep and then does not wake up. I am using SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk; along with __WFI(); to put it to sleep. I am not sure if I have been putting it in the wrong spot, or what the issue is.
In the end, I would like it to be asleep, wake up when it moves, and then go back to sleep. I have been searching for help and messing with it for a few days now, and not being able to figure out what to use or where to put things is driving me kind of nuts! Any help would be appreciated.
Code:
#include <Arduino.h>
#include <Wire.h>
#include “Sodaq_RN2483.h”
#include “Sodaq_wdt.h”
#include “LIS3DE.h”
#include “RTCTimer.h”
#include “RTCZero.h”
#define debugSerial SerialUSB
#define loraSerial Serial1
#define MAX_RTC_EPOCH_OFFSET 25
#define sleep = 0;
RTCZero rtc;
RTCTimer timer;
LIS3DE accelerometer;
double x, y, z;
String xDoble, yDouble, zDouble;
volatile bool isOnTheMoveActivated;
volatile uint32_t lastOnTheMoveActivationTimestamp;
uint32_t getNow();
void initRtc();
void rtcAlarmHandler();
void resetRtcTimerEvents();
void accelerometerInt1Handler();
volatile bool minuteFlag;
static bool isOnTheMoveInitialized;
void setAccelerometerTempSensorActive(bool on);
pinMode(LED_RED, OUTPUT);
digitalWrite(LED_RED, HIGH);
// Power up the LoRaBEE
pinMode(ENABLE_PIN_IO, OUTPUT); // ONE
digitalWrite(ENABLE_PIN_IO, HIGH); // ONE
delay(3000);
Wire.begin();
// Wait 10 seconds for the Serial Monitor
while ((!SerialUSB) && (millis() < 10000)){}
// Set baud rate
debugSerial.begin(57600);
loraSerial.begin(LoRaBee.getDefaultBaudRate());
debugSerial.println(“Starting…”);
isOnTheMoveInitialized = true;
// Activate interrupt on the move
initOnTheMove();
void loop(){
digitalWrite(LED_RED, LOW);
x=accelerometer.getX();
y=accelerometer.getY();
z=accelerometer.getZ();
//debugSerial.print("X: "); debugSerial.println(x);
//debugSerial.print("Y: "); debugSerial.println(y);
debugSerial.print("Z: "); debugSerial.println(z);
// Initializes the on-the-move functionality (interrupt on acceleration).
void initOnTheMove() {
pinMode(ACCEL_INT1, INPUT);
attachInterrupt(ACCEL_INT1, accelerometerInt1Handler, CHANGE);
// Configure EIC to use GCLK1 which uses XOSC32K, XOSC32K is already running in standby
// This has to be done after the first call to attachInterrupt()
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID(GCM_EIC) |
GCLK_CLKCTRL_GEN_GCLK1 |
GCLK_CLKCTRL_CLKEN;
accelerometer.enable(true, LIS3DE::NormalLowPower10Hz, LIS3DE::XYZ, LIS3DE::Scale4g, true);
sodaq_wdt_safe_delay(10);
accelerometer.enableInterrupt1(
LIS3DE::XHigh | LIS3DE::XLow | LIS3DE::YHigh | LIS3DE::YLow | LIS3DE::ZHigh | LIS3DE::ZLow,
18.75 * 8.0 / 100.0,
0,
LIS3DE::MovementRecognition);
// Runs every time acceleration is over the limits set by the user (if enabled).
void accelerometerInt1Handler() {
if (digitalRead(ACCEL_INT1)) {
debugSerial.println(“On-the-move is triggered”);
isOnTheMoveActivated = true;
lastOnTheMoveActivationTimestamp = getNow();
  • Initializes the accelerometer or puts it in power-down mode
  • for the purpose of reading its temperature delta.
    void setAccelerometerTempSensorActive(bool on) {
// if on-the-move is initialized then the accelerometer is enabled anyway
if (isOnTheMoveInitialized) {
return;
if (on) {
accelerometer.enable(false, LIS3DE::NormalLowPower100Hz, LIS3DE::XYZ, LIS3DE::Scale2g, true);
sodaq_wdt_safe_delay(30); // should be enough for initilization and 2 measurement periods
accelerometer.disable();
  • Returns the current datetime (seconds since unix epoch).
    uint32_t getNow()
    return rtc.getEpoch();
    void initRtc()
    rtc.begin();
    // Schedule the wakeup interrupt for every minute
    // Alarm is triggered 1 cycle after match
    rtc.setAlarmSeconds(1);
    rtc.enableAlarm(RTCZero::MATCH_SS); // alarm every minute
// Attach handler
rtc.attachInterrupt(rtcAlarmHandler);
// This sets it to 2000-01-01
rtc.setEpoch(0);
  • Runs every minute by the rtc alarm.
    minuteFlag = true;
  • Initializes the RTC Timer and schedules the default events.
    void initRtcTimer()
    timer.setNowCallback(getNow); // set how to get the current time
    timer.allowMultipleEvents();
