My name is Ernesto, i’m working on a project with module esp01, the idea is to have a door alarma with magnetic sensor. In the developing phase I’ve runned into a Soft WDT reset issue.
This is my code:
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
// Wifi network station credentials
#define WIFI_SSID "Imperio1"
#define WIFI_PASSWORD "Sistemas20"
// Telegram BOT Token (Get from Botfather)
#define BOT_TOKEN "5081397447:AAGoQ0SzdLuZHgQAcHOiEhPgT6oDxCzYSBo"
#define CHAT_ID "-680973127"
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
WiFiClientSecure secured_client;
UniversalTelegramBot bot(BOT_TOKEN, secured_client);
const unsigned long BOT_MTBS = 1000; // tiempo medio entre mensajes escaneados
unsigned long bot_lasttime; // última vez que se realizó el escaneo de mensajes
const int sensorPuerta = 2;
int abierto = 0;
int cerrado = 0;
bool estadoAlarma = 0;
//String chat_id;
// attempt to connect to Wifi network:
Serial.print("Connecting to Wifi SSID ");
Serial.print(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
secured_client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.print("\nWiFi connected. IP address: ");
Serial.print("Retrieving time: ");
configTime(0, 0, "pool.ntp.org"); // get UTC time via NTP
time_t now = time(nullptr);
while (now < 24 * 3600)
Serial.print(".");
delay(100);
Serial.println(now);
bot.sendMessage(CHAT_ID, "📡 Wifi Conectado!!", "");
pinMode(sensorPuerta, INPUT);
if (millis() - bot_lasttime > BOT_MTBS)
int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
while (numNewMessages)
//Serial.println("Llego un mensaje!!");
handleNewMessages(numNewMessages);
bot_lasttime = millis();
int lectura = digitalRead(sensorPuerta);
delay(100);
if (estadoAlarma == 1 && lectura == 0){
abierto ++;
imprimeAbierto(abierto, lectura);
cerrado = 0;
}else if(estadoAlarma == 1 && lectura == 1){
//Serial.println(lectura);
abierto = 0;
cerrado ++;
imprimeCerrado(cerrado, lectura);
void handleNewMessages(int numNewMessages)
Serial.print("handleNewMessages ");
Serial.println(numNewMessages);
for (int i = 0; i < numNewMessages; i++)
String chat_id = bot.messages[i].chat_id;
String text = bot.messages[i].text;
String from_name = bot.messages[i].from_name;
if (from_name == "") from_name = "Guest";
if (text == "/armado"){
estadoAlarma = 1;
Serial.print("Panel de alarmas: ARMADO - ");
Serial.println(estadoAlarma);
bot.sendMessage(chat_id, "📟 Panel de alarmas: ✅ ARMADO", "");
}else if (text == "/desarmado"){
estadoAlarma = 0;
Serial.print("Panel de alarmas: DESARMADO - ");
bot.sendMessage(chat_id, "📟 Panel de alarmas: ❌ DESARMADO", "");
}else{
Serial.print("Comando No reonocido...");
bot.sendMessage(chat_id, "Comando No reconocido 🚫", "");
void imprimeAbierto(int abierto, int lectura){
if (abierto < 2){
Serial.print("Puerta Abierta - ");
bot.sendMessage(CHAT_ID, " Puerta Abierta 🚪🟢", "");
void imprimeCerrado(int cerrado, int lectura){
if (cerrado < 2){
Serial.print("Puerta Cerrada - ");
bot.sendMessage(CHAT_ID, " Puerta Cerrada 🚪🔴", "");
type or paste code here
This is the error
handleNewMessages 1
Panel de alarmas: ARMADO - 1
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffcc0 end: 3fffffc0 offset: 01a0
3ffffe60: 03d19744 00000020 3fff23bc 401008de
3ffffe70: 3ffef000 00000000 4020bc28 00000000
3ffffe80: 0000dbb5 00000000 3ffef050 40206b87
3ffffe90: 00000000 003d003f 00000000 00000000
3ffffea0: 000b000f 00000000 00000020 40100908
3ffffeb0: 3fffff10 00000000 3fff8498 00000000
3ffffec0: 3fffff10 3ffffef8 3ffe8fd9 40204968
3ffffed0: 3ffe8f8f 3ffffef8 00000000 3fffff6c
3ffffee0: 3fffff78 3ffef050 00000000 40206ce9
3ffffef0: 3ffe885c 00000020 3fff7edc 3fff7f00
3fffff00: 3fff8498 3fff84b8 3ffef000 4020779e
3fffff10: 3fff84a8 3fff8498 00000020 3ffef248
3fffff20: 3fffff10 3ffffef8 3fffff6c 40208663
3fffff30: 3fffff60 00000000 3fffff78 402086d4
3fffff40: 3fffdad0 3ffe8f8f 3fffff78 3ffef248
3fffff50: 3fffdad0 3ffef04c 00000001 40201121
3fffff60: 3038362d 31333739 0a003732 3fff23d4
3fffff70: 0018001f 80000000 00000000 40208cf8
3fffff80: 00000000 00000064 3ffef248 402093a6
3fffff90: 3fffdad0 3ffef04c 00000001 402014c4
3fffffa0: 3fffdad0 00000000 3ffef234 40208e18
3fffffb0: feefeffe feefeffe 3ffe8640 40100b99
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00063480
~ld
pls helpme
