Soft WDT reset when using a function taking an address (call by reference)
I'm getting the following dump on the serial port (USB) (sorry, copy/paste somehow doesn't work from the serial console, so please see the attached image). I'm going to try to avoid adding a lot of extra code - but here's a short version of the code segment(s) that fail:
int isTime(unsigned long *fromMillis, unsigned long maxMillis) {
  unsigned long n=millis();
  Serial.println("isTime called");
  if ((n - (*fromMillis)) >= maxMillis) {
    // Time expired - do action
    *fromMillis = n; // Reset Count
    return true;
  return false;
    static unsigned long sensorTime = 0;
    static uint16_t dist=100, strength=5000;
    if (isTime(&sensorTime, 100)) {
        dist = tfmini.getDistance();
        strength = tfmini.getRecentSignalStrength();
That's it - the code fails in "isTime" when called from the function above (the assignment of *fromMillis seems to be it). This function is called A LOT and I only see it called once using debug statements. running this code segment directly in gcc works just fine:
#include <stdio.h>
#include <stdbool.h>
#include <time.h>
#include <stdlib.h>
long long gettimeofday_ms() {
  struct timespec ts;
  clock_gettime(CLOCK_MONOTONIC, &ts);
  long long ms = ts.tv_sec*1000LL + 1e-6*ts.tv_nsec;
  return ms;
bool isTime(long long *fromMillis, long long maxMillis) {
  long long now=gettimeofday_ms();
  if ((now - *fromMillis) >= maxMillis) {
    *fromMillis = now; // Reset Count
    return true;
  return false;
long long waits[] = {200,600,1200,5000,2000};
void main() {
  long long now = gettimeofday_ms();
  for (int i=0;i<5;i++) {
    while (!isTime(&now, waits[i])) { };
    printf("Wait %d is complete - was %ld. ms=%lld\n", i, waits[i], now);
Outside of the call to millis() being replaced by standard C's time feature, this works. I know "millis()" returns unsigned long, so no "long long" is required.
Does anyone see what I fat-fingered wrong here?
Is the device a ESP32 or ESP8266?
Install and use the ESP Exception Decoder GitHub - me-no-dev/EspExceptionDecoder: Exception Stack Trace Decoder for ESP8266 and ESP32
If you highlight the text in the serial console, and use the keyboard command of control-c to copy you can then paste.
Idahowalker:
ESP8266 - Wemo d1 mini.
I've tried but the menu doesn't show up. I've placed it in same parent directory "libraries" is in, but the tools menu doesn't change.
21:56:58.975 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:56:58.975 ->
21:56:58.975 -> Soft WDT reset
21:56:58.975 ->
21:56:58.975 -> >>>stack>>>
21:56:58.975 ->
21:56:58.975 -> ctx: cont
21:56:58.975 -> sp: 3ffffd60 end: 3fffffc0 offset: 01a0
21:56:58.975 -> 3fffff00: 40202c30 3ffee888 3ffe89ab 40202ec5
21:56:59.008 -> 3fffff10: 00000064 0000000d 3ffee7e0 40205902
21:56:59.008 -> 3fffff20: 00000064 000000a8 3ffee888 40202f70
21:56:59.008 -> 3fffff30: 3ffee7e0 0000000b 3ffee7e0 40202b8c
21:56:59.008 -> 3fffff40: 3fffdad0 3ffee888 3ffe84ce 402013be
21:56:59.008 -> 3fffff50: 0001c200 3ffee888 3ffee888 40202f70
21:56:59.008 -> 3fffff60: 0001c200 3ffee888 3ffee7ec 40201148
21:56:59.008 -> 3fffff70: 00000040 00000000 feefeffe feefeffe
21:56:59.041 -> 3fffff80: 0000004d 00000096 00000050 00000064
21:56:59.041 -> 3fffff90: 00000032 feefeffe feefeffe 3ffee9a4
21:56:59.041 -> 3fffffa0: 3fffdad0 00000000 3ffee964 40203ca8
21:56:59.041 -> 3fffffb0: feefeffe feefeffe 3ffe8794 40101819
21:56:59.041 -> <<<stack<<<
21:56:59.041 ->
21:56:59.041 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:56:59.074 ->
21:56:59.074 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
I swear I tried that ... well, now it works! Thanks!
Update - no go on the EspExceptionDecoder - it requires "rather old" python and ncurses libraries - Fedora 32 finally got rid of Python2, now 5 (I'm pretty sure) years after it was deprecated. So all I get is a prompt of an ELF binary which most likely is the python2.7 executable.
That said - I've noticed the stack trace comes before the setup() debug statement. But since I can add more statements before the one I pointed out and they are all output after the stack-dump it seems like a buffer issue to me. Clearly the unit is resetting due to a software error. I can run other code on the Wemo D1, from "blinky" to more complex code. So it's not a hardware issue.
