We all know the situation:
We spent so much time to build a project, but then something does not work...
Is the bug in my code, pin configuration, the wiring, defective hw items or where does it hide?
It would be so helpful being able to switch pin configuration/state for a test, or read and display it, watch the changing values that this new sensor delivers, try which PWM value is a good starting value for that robot, ... without having to add ever changing debug code to your sketch.
Thats why I wrote softboard.
First I included similar code in just about every sketch I wrote,
now I have factored it out to run as standalone sketch.
get it from GitHub - reppr/softboard: arduino software breadboard
Try it out, have fun,
Robert
from README softboard:
Arduino software breadboard.
Hardware/software developing/testing tool.
Simple hardware menu interface over serial line
as a kind of software breadboard
Read/set I/O pin configuration and states, switch pins on/off.
Read and write digital and analog values, switch pullup/high-z,
watch changing inputs over time.
Send 'm' over serial line and a menu will be sent back
displaying info on its one-letter commands.
Easy to write your own menu, but not documented yet...
Use it together with your own programs.
Installation:
Get it from GitHub - reppr/softboard: arduino software breadboard
Move the 'softboard' folder with all files
to your arduino sketchbook/ folder.
Load the sketch from arduino menu Files>Sketchbook>softboard.
Example 1: 'P13 OH' switch LED on (P select pin, O output, H high)
'L' off again (L low)
Example 2: 'P13 IH' pullup LED pin (P select pin, I input, H high)
LED glows at low level
'O' LED as OUTPUT now the LED is on
Example 3: Watch an analog input like a VU meter, changing over time.
See electric noise on unconnected floating A2 input
scrolling over your serial terminal.
(Touch the input if there is no visible signal.)
Now connect a sensor to the input and explore its data...
'P2 v' P=select pin (both analogue or digital)
v=display analog read values and bar graphs
175 ***********
190 ************
192 *************
181 ************
163 ***********
158 **********
164 ***********
181 ************
192 *************
190 ************
176 ************
161 ***********
159 **********
168 ***********
186 ************
194 *************
188 ************
170 ***********
Example 4: 'a' Display snapshot values on analog inputs.
[fixed font only]
pin value | | |
0 609 ***************************************
1 504 ********************************
2 451 *****************************
3 398 *************************
4 383 ************************
5 409 **************************
Example 5: '.' Display info about all pin's I/O configuration and states.
pin 0 I hi-z
pin 1 I hi-z
pin 2 O high
pin 3 O low
pin 4 I hi-z
*pin 5 I pullup // * indicates the selected pin
pin 6 I hi-z
pin 7 I hi-z
pin 8 I hi-z
pin 9 I hi-z
pin 10 I hi-z
pin 11 I hi-z
pin 12 I hi-z
pin 13 I pullup
