SoftI2Cl library and Leonardo
So i'm messing around with the following:
I have a custom made shield to operate with an Uno. I now want to update it to a Leonardo because I've found a batch laying around. Trick is, the Uno has it's SDA and SCL on A4 and A5, both connected to the SDA and SCL pins next to AREF. The Leonardo has the SDA and SCL pins on 2 and 3, also connected to the SDA and SCL pins next to the AREF. The custom shield we have already uses pins 2 and 3 for something else, so I want the I2C to relocate to A4 and A5! So I downloaded the softI2Cmaster library (Found here: Arduino Playground - SoftwareI2CLibrary)
And I adjusted the ports to PORTF and SDA/SCL pins (According to the pinout: https://www.arduino.cc/en/Hacking/PinMapping32u4).
When running the I2CScanSoft example, it doesn't do anything.. According to the example the SDA and/or SCL lines "are low"...
code:
// Scan I2C bus for device responses
#define SDA_PORT PORTF
#define SDA_PIN 7
#define SCL_PORT PORTF
#define SCL_PIN 6
#define I2C_TIMEOUT 100
#define I2C_NOINTERRUPT 0
#define I2C_FASTMODE 1
#define FAC 1
#define I2C_CPUFREQ (F_CPU/FAC)
/* Corresponds to A4/A5 - the hardware I2C pins on Arduinos
 #define SDA_PORT PORTC
 #define SDA_PIN 4
 #define SCL_PORT PORTC
 #define SCL_PIN 5
#include <SoftI2CMaster.h>
#include <avr/io.h>
void CPUSlowDown(int fac) {
  // slow down processor by a fac
  CLKPR = _BV(CLKPCE);
  CLKPR = _BV(CLKPS1) | _BV(CLKPS0);
void setup(void) {
#if FAC != 1
  CPUSlowDown(FAC);
#endif
void loop(void)
  if(Serial.available())
    Serial.begin(115200); // change baudrate to 2400 on terminal when low CPU freq!
    Serial.println(F("Intializing ..."));
    Serial.print("I2C delay counter: ");
    Serial.println(I2C_DELAY_COUNTER);
    int temp = 1;
    while(temp==1)
    if (!i2c_init())
      Serial.println(F("Initialization error. SDA or SCL are low"));
      Serial.println(F("...done"));
      temp=0;
    while(1)
      uint8_t add = 0;
      int found = false;
      Serial.println("Scanning ...");
      Serial.println("       8-bit 7-bit addr");
      // try read
      do {
        Serial.println(add, HEX);
        if (i2c_start(add | I2C_READ)) {
          found = true;
          i2c_read(true);
          i2c_stop();
          Serial.print("Read:   0x");
          if (add < 0x0F) Serial.print(0, HEX);
          Serial.print(add+I2C_READ, HEX);
          Serial.print("  0x");
          if (add>>1 < 0x0F) Serial.print(0, HEX);
          Serial.println(add>>1, HEX);
        else i2c_stop();
        add += 2;
      while (add);
I have adjusted some of the example to have a better control over when the scanning starts and when not.
I have also tried to enable and disable the pull-up resistors and swapping the pins, without effect.
It'll probably be a small thing, but with my heavy case of tunnel vision and a lack of coffee i'm not able to find the problem... Does someone have an idea on what the problem could be or how to continue?
Thanks in advance!
#define SDA_PIN 7
#define SCL_PIN 6
Just a guess but A4 & A5 are pins 1 & 0 respectfully. Pin 6 & 7 are A1 & A0.
Riva:
Yeah thats what I was guessing to, because the schematic.pdf on the Leo page was "wrong". I've been trying both 0&1 and 6&7 with every thing I try. Unfortunately it has no effect...
Having a look at the library and it seems to be geared towards the 328 chip. Not sure how different the architecture is between the 328 and 32u4 but I guess it's enough to prevent assemble code from working.
this means either find/write an assembler version suitable for the 32u4 of find a C++ version that is fast enough for your needs.
I to delved into the code of the library in the mean time, and I decided to look for another.
Found an Adafruit library and that one is working! Found it here: http://forums.adafruit.com/viewtopic.php?f=25&p=66953
Adjusted it a little bit to support the 32U4.
