Softserial and atmega8
So, I'm creating a project with 3 simultaneous rfid readers, getting data via Softserial. I've got it working with my Uno, and am trying to find a way to make it into a standalone thing.
For the rfid readers I need 6 pins (Tx + Rx )x3 (duh!) so I can't use the tiny85 I normally use for standalone stuff.
Maybe I'm saying a dumb thing here, but from what I understand, softserial operates with external interrupts. I have some atmega8 lying here, but from the specs on the atmel website the atmega8 supports 2 external interrupts, so it wouldn't be enough for what I need.
The attiny84 should work, but before buying some, I wanted to make sure there is no way the atmega8 would work (maybe I'm understanding softserial totally wrong) and thought of checking up with you guys. I need at least 8kb mem (sketch is roughly 7k) and those rx+tx ports I said before, so if there is any other better solution for the chip, let me know.
Thanks a lot!
Ishkur:
Pin change interrupts not external interrupts. Software Serial works on any pair of pins.
Yes, but according to Atmega8 datasheet this uC does not seem to have PCINT (pin change interrupt pins). Atmega328 has many.
Yup. No pin change interrupts for the ATmega8.
Oh, pin change interrupts. Ok, I was right to think I was understanding it wrong :stuck_out_tongue:
So, actually, the attiny85 would work, since it has 6 pins with PCINT capability, right?
Ishkur:
Yes with some caveats...
• RESET has to be disabled for PB5 to be used as an I/O pin
• Once RESET is disabled, SPI programming is no longer available. You can use either "high voltage" programming or a bootloader.
• To restore RESET you have to use high voltage programming
• PB5 is included in the Tiny Core pin mapping. I have no idea if it's included in the MIT HLT pin mapping. If you are using the HLT pin mapping you may have to add PB5.
I almost always use arduino to burn bootloader and upload sketches to the tinys (just made a pcb with fast connections, only have to change the ic :P)
Can you link me to the tiny core files, please? I've been using the mit cores.
And thanks a lot again, saved me a lot of time and some money too hehe
Ishkur:
Before you commit to the ATtiny85 processor I want to make certain you understand. I'll start with some questions regarding your ATtiny work...
• When you "burn bootloader", is your intent is to change the fuse settings?
• Are you using an Arduino board running the ArduinoISP sketch to upload? If not, what are you using?
• I know there is an actual bootloader for the ATtiny85. Have you downloaded it or were you given a copy by someone?
http://code.google.com/p/arduino-tiny/
You are welcome.
I'm using the arduino ISP sketch, yes. Until now I've never had to change fuse settings, I'm just using the core files from MIT and uploading the sketches I've run on the Uno before (of course I take care of what instructions work on the tiny).
When I talk about bootloader, I mean the "burn bootloader" command on the arduino ide, before uploading any sketch to the tiny.
Ishkur:
The ArduinoISP sketch uses SPI to program the target. After disabling RESET you will not be able to use the ArduinoISP sketch to make any changes to the target including changing the fuses. Unless you have a high voltage programmer, disabling RESET is a one way path. If you first install a bootloader, you will still be able to upload sketches but you will not be able to make any other changes to the target.
In other words, if you did not first install an actual bootloader the target will be "bricked" until you have access to a high voltage programmer.
You will have to install an actual bootloader before disabling RESET. I suggest you first try installing and using a bootloader before taking that final step of disabling RESET.
Hummmm ok, I will do so. How should I do that?
"Manually" with avrdude? Never actually tried to do that. And what kind of connection should I get? USB to TTL is also SPI, right?
