Softserial problem / using uart possible?
Hello, I'm using the GSM-Shield and I want to ask for using another serial port. With an Uno or Mini Pro everything is working but if I want to use my Mega I've got the problem that I get his error-message: I want to use UART 2.
C:\Program Files (x86)\Arduino\libraries\GSM\GSM3CircularBuffer.cpp: In member function 'void GSM3CircularBuffer::debugBuffer()': C:\Program Files (x86)\Arduino\libraries\GSM\GSM3CircularBuffer.cpp:269:2: error: 'Serial' was not declared in this scope C:\Program Files (x86)\Arduino\libraries\GSM\GSM3CircularBuffer.cpp: In static member function 'static void GSM3CircularBuffer::printCharDebug(uint8_t)': C:\Program Files (x86)\Arduino\libraries\GSM\GSM3CircularBuffer.cpp:282:3: error: 'Serial' was not declared in this scope C:\Program Files (x86)\Arduino\libraries\GSM\GSM3CircularBuffer.cpp:285:3: error: 'Serial' was not declared in this scope
How can I use another seriell port than the softserial?
Thanks a lot!
I found in GSM2ShieldV1.cpp this text:
#include <GSM3ShieldV1.h>
#include <HardwareSerial.h>
How can I use it???
If I can remember, Mega has three Serials, Serial1, Serial2 and Serial3. Replace Serial with Serial1, Serial2 or Serial3.
Mega has 4 serial ports: Serial, Serial1, Serial2 and Serial3.
You initialize them all the same: Serial.begin(9600); Serial1.begin(9600); Serial2.begin(9600); Serial3.begin(9600);
Subbing them straight in to a library written to support a software serial implementation may require some other tweaking as well.
