Softtimer (Debouncer) && Pcimanager don't react on inputs...
Hello there!
I have installed the libraries “Softimer” and “Pcimanager”.
The two simple example don’t work for me.
The examples are running and the “Ready.” is shown in the Terminal, so the Communication work.
But the HIGH signal on Pin 3 doesn,t do anything.
Softtimer:
arduino-softtimer/SoftTimer6Debouncer1.ino at master · prampec/arduino-softtimer · GitHub
Pcimanager:
arduino-pcimanager/PciManager1Basic.ino at master · prampec/arduino-pcimanager · GitHub
I have the new “ARDUINO IDE 1.6.12” maybe this is the problem?
I am really glad about every reference…
Thank you!
Martin
Phenix:
Correct. What did you expect a high signal to do? Both examples will only do anything unless the signal changes between high and low.
Of course I have a button which change the signal from low to high...
How is the switch wired?
With a “digitalread” application it works fine…
Yes, this is the circuit.
Martin, what are those circle symbols? Voltage sources of some kind? What voltage? Why the complex circuit just to read a switch?
The left source is only a symbol of for the complex circle.
The reason for the "switch-circle" is to send a clean switch signal to the arduino!
Phenix:
Sorry, what?
Phenix:
Clean in what way? Your circuit does not debounce the switch...
No, there is a complex circuit instead of the left source it's only a symbole.
The voltage is not 5V there and a perfect switch isn't there, too.
