Software compatibility
Could somebody let me know if Arduino Due is software compatible with the other Arduino platforms (Uno-Mega)
Many thanks in advanced
If you are asking will it be programmable using the same IDE the answer is yes. If you're asking if a sketch from a Uno can be used directly on the Due, and vice versa, that depends on what it does. The same answer applies between Uno and Mega etc, as there are unique capabilities on each board that the others do not necessarily share.
Is there anything specifically you were looking to run on both a Uno and Due?
Geoff
