I tried it, and is still crashes. Here is a log of the crash after I renamed C:\Program Files\Arduino\Java
A fatal error has been detected by the Java Runtime Environment:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00000000, pid=3452, tid=1132
JRE version: 6.0_17-b04
Java VM: Java HotSpot(TM) Client VM (14.3-b01 mixed mode, sharing windows-x86 )
Problematic frame:
C 0x00000000
If you would like to submit a bug report, please visit:
Bug Report
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x010c4c00): JavaThread "AWT-Windows" daemon [_thread_in_native, id=1132, stack(0x03b00000,0x03b50000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x03b4f6ec, EBX=0x00000001, ECX=0x0000000a, EDX=0x00000004
ESP=0x03b4f4f8, EBP=0x03b4f530, ESI=0x010c4d10, EDI=0x00009824
EIP=0x00000000, EFLAGS=0x00010283
Top of Stack: (sp=0x03b4f4f8)
0x03b4f4f8: 6d07cc4b 03b4f6ec 6d09bf8c 03b4f6ec
0x03b4f508: 03b4f598 6d09b8e0 00000000 00000000
0x03b4f518: 00000002 010c4d10 03b4f508 03b4f5b4
0x03b4f528: 6d0bf268 ffffffff 03b4f55c 7e418734
0x03b4f538: 00020194 00009824 6d07cc40 03b4f6ec
0x03b4f548: 6d09b8e0 dcbaabcd 00000000 03b4f598
0x03b4f558: 6d09b8e0 03b4f5c4 7e418816 6d09b8e0
0x03b4f568: 00020194 00009824 6d07cc40 03b4f6ec
Instructions: (pc=0x00000000)
0xfffffff0:
Stack: [0x03b00000,0x03b50000], sp=0x03b4f4f8, free space=317k
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.awt.windows.WToolkit.eventLoop()V+0
j sun.awt.windows.WToolkit.run()V+69
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x035df000 JavaThread "Thread-5" [_thread_in_native, id=3628, stack(0x04370000,0x043c0000)]
0x01054400 JavaThread "DestroyJavaVM" [_thread_blocked, id=3488, stack(0x01260000,0x012b0000)]
0x03572c00 JavaThread "TimerQueue" daemon [_thread_blocked, id=3616, stack(0x04280000,0x042d0000)]
0x03572800 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3612, stack(0x04230000,0x04280000)]
0x0114fc00 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=3568, stack(0x041c0000,0x04210000)]
0x010f3000 JavaThread "AWT-Shutdown" [_thread_blocked, id=3564, stack(0x03ab0000,0x03b00000)]
=>0x010c4c00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1132, stack(0x03b00000,0x03b50000)]
0x010f5000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1684, stack(0x03a60000,0x03ab0000)]
0x010ae000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3308, stack(0x039c0000,0x03a10000)]
0x0391f800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1692, stack(0x03970000,0x039c0000)]
0x0391f400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1652, stack(0x03920000,0x03970000)]
0x0106f000 JavaThread "Finalizer" daemon [_thread_blocked, id=3312, stack(0x034d0000,0x03520000)]
0x0106e800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1268, stack(0x03480000,0x034d0000)]
Other Threads:
0x0106e400 VMThread [stack: 0x03430000,0x03480000] [id=1244]
0x010ae800 WatcherThread [stack: 0x03a10000,0x03a60000] [id=1604]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 9088K, used 7779K [0x1e990000, 0x1f360000, 0x1f360000)
eden space 8128K, 85% used [0x1e990000, 0x1f054da8, 0x1f180000)
from space 960K, 88% used [0x1f270000, 0x1f3441c8, 0x1f360000)
to space 960K, 0% used [0x1f180000, 0x1f180000, 0x1f270000)
tenured generation total 121024K, used 0K [0x1f360000, 0x26990000, 0x26990000)
the space 121024K, 0% used [0x1f360000, 0x1f360000, 0x1f360200, 0x26990000)
compacting perm gen total 12288K, used 1868K [0x26990000, 0x27590000, 0x2a990000)
the space 12288K, 15% used [0x26990000, 0x26b63220, 0x26b63400, 0x27590000)
ro space 8192K, 63% used [0x2a990000, 0x2aea8b20, 0x2aea8c00, 0x2b190000)
rw space 12288K, 53% used [0x2b190000, 0x2b805138, 0x2b805200, 0x2bd90000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe
0x7c900000 - 0x7c9b2000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f6000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
0x7e410000 - 0x7e4a1000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll
0x5cb70000 - 0x5cb96000 C:\WINDOWS\system32\ShimEng.dll
0x71590000 - 0x71604000 C:\WINDOWS\AppPatch\AcLayers.DLL
0x7c9c0000 - 0x7d1d7000 C:\WINDOWS\system32\SHELL32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\msvcrt.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll
0x769c0000 - 0x76a74000 C:\WINDOWS\system32\USERENV.dll
0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x6f880000 - 0x6fa4a000 C:\WINDOWS\AppPatch\AcGenral.DLL
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x77120000 - 0x771ab000 C:\WINDOWS\system32\OLEAUT32.dll
0x77be0000 - 0x77bf5000 C:\WINDOWS\system32\MSACM32.dll
0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\UxTheme.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
0x773d0000 - 0x774d3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x7c340000 - 0x7c396000 C:\PROGRA~1\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da8b000 C:\PROGRA~1\Java\jre6\bin\client\jvm.dll
0x6d7b0000 - 0x6d7bc000 C:\PROGRA~1\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\PROGRA~1\Java\jre6\bin\java.dll
0x6d290000 - 0x6d298000 C:\PROGRA~1\Java\jre6\bin\hpi.dll
0x6d7f0000 - 0x6d7ff000 C:\PROGRA~1\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x10000000 - 0x1002e000 C:\Program Files\ATI Technologies\ATI HYDRAVISION\HydraDMH.dll
0x74720000 - 0x7476c000 C:\WINDOWS\system32\MSCTF.dll
0x77b40000 - 0x77b62000 C:\WINDOWS\system32\apphelp.dll
0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x5b860000 - 0x5b8b5000 C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000 C:\Program Files\Java\jre6\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\System32\mswsock.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x16080000 - 0x160a5000 C:\Program Files\Bonjour\mdnsNSP.dll
0x76d60000 - 0x76d79000 C:\WINDOWS\system32\Iphlpapi.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
0x04130000 - 0x0417c000 C:\Documents and Settings\Steve\Local Settings\Temp\jna9217660857771135119.tmp
0x6d230000 - 0x6d284000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x6d630000 - 0x6d639000 C:\Program Files\Java\jre6\bin\nio.dll
0x04210000 - 0x04222000 C:\Program Files\Arduino\rxtxSerial.dll
0x73d90000 - 0x73db7000 C:\WINDOWS\system32\crtdll.dll
0x662b0000 - 0x66308000 C:\WINDOWS\system32\hnetcfg.dll
0x71a90000 - 0x71a98000 C:\WINDOWS\System32\wshtcpip.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\COMDLG32.DLL
VM Arguments:
jvm_args: -Xms128m -Xmx128m
java_command: processing.app.Base
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files\QuickTime\QTSystem\QTJava.zip
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\QuickTime\QTSystem;C:\Program Files\Common Files\DivX Shared;C:\Program Files\Java\jre6\bin
USERNAME=Steve
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 107 Stepping 2, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 98 Build 67766446
CPU:total 2 (2 cores per cpu, 1 threads per core) family 15 model 107 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 1047724k(457096k free), swap 2520724k(1792552k free)
vm_info: Java HotSpot(TM) Client VM (14.3-b01) for windows-x86 JRE (1.6.0_17-b04), built on Oct 11 2009 00:52:06 by "java_re" with MS VC++ 7.1
time: Fri Nov 20 22:46:39 2009
elapsed time: 6 seconds
Thanks for the reply, I hope I can get this fixed one of these days. Unfortunately, I'm in way over my head on this one.
Steve
