software on windows 7
HI, first day with arduino, sorry for the noob question. I am trying to use the software under windows 7, but it doesn't work when I launch it it gives an error, There's a JavaWindow saying... "could not fine the main class: processing.app.base. Program will exit"
first question. does it work under windows 7 second question. if yes, what's the problem then?
thx in advance
works fine on 7
Some computers have issues with arduino 0017 and its normally a java problem. Try updating java.
I just downloaded Java Runtime before installing Arduino Software... I'll try the update but I guess I have the latest version...
check out this thread i found this morning it may help.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1255462031
thanks guys, and forget about it. ;-)
the ZIP file wan't expanded correctly, i was using Windows "internal" uncompression function and I discovered many files were missing. Simply unzipped again and everything works as expected.
thx anyway!
