I have a led dimmer project with 3 switches 1 to increase intensity, 1 to decrease intensity and 1 to cycle through 5 fixed intensities. now based on the switch inputs i generate a pwm using the analogWrite() function. This works fine. Now the challenge is I have to port this project to PIC 12F675 and it does not have a hardware PWM option. so I need to write a software PWM nad i have been trying it out on arduino. Now how do i do this on the arduino? i know i can set it for one time execution by putting it inside an infinite loop. Now how do i create a software pwm that i can use?( just trigger it on and go ahead with other routines till there is some interrupt from the switches to modify the intensity?)
I threw something together real quick, but haven’t had the chance to test it out yet. Test it and let me know how it works.
Setup:
Connect a voltmeter to pin 13 on the board and ground. 2.5 volts is our target.
#define OUTPIN 13
pinMode (OUTPIN, OUTPUT);
int i = 0;
if(i % 2) //if you don't know what the % operator is: go here http://arduino.cc/en/Reference/Modulo
digitalWrite(OUTPIN, HIGH);
//else
digitalWrite(OUTPIN, LOW);
i++;
So everytime, the arbitrary counter “i” is evenly divisible by 2. I turn on the output, else the output is off.
Let me know how this works out. I understand that my explanation is horrid, but I’m hoping you understand…if not, then I’d be glad to explain.
Here’s some PWM code in C (actually from a PIC12f675-based project, but it should work fine on Arduino given appropriate implementation of getbright(), led_all_on(), and ledN_off…
while (1) { // forever
getbright();
for (level_delay = 50; level_delay != 0; level_delay--) {
pwm1 = bright1;
pwm2 = bright2;
pwm3 = bright3;
pwm4 = bright4;
pwm5 = bright5;
led_all_on();
for (pwm_delay = 128; pwm_delay !=0; pwm_delay--) {
* We have a random number in each PWM between 1 and 128
* and we're going to have 128 cycles of delay. So each
* decremented output can only cross zero once, at which
* time we toggle the output state.
if (--pwm1 == 0) {
led1_off;
if (--pwm2 == 0) {
led2_off;
if (--pwm3 == 0) {
led3_off;
if (--pwm4 == 0) {
led4_off;
if (--pwm5 == 0) {
led5_off;
} /* time for new PWM cycle */
} /* time for new brightness */
} /* while forever */
Is this the complete code? Can you post the complete code? the gled_all_on() and ledN_off() functions in specific. I’ve done the getbright() part but not sure of how exactly to turn on the leds. say for example, when i say analogWrite(11,200); pin 11 stays at 200 till i modify it
able to generate maximum of 3.18v by varying the base value for the mod operator(i%15)
now my concern is how to trigger this on, forget about it and then interrupt it again to change it.i think i need some kind of a timer interrupt… not sure how that works
