Software PWM on Due
I have a lamp matrix where using the analogWrite() function is too slow to properly maintain the strobing without flicker, but using the direct digital call works. The lamp matrix is strobed on a 1ms timer, so a full cycle of the full matrix is 8ms.
void lampMatrix() {
  lampColumnLast = lampColumn;
  lampColumn++;        // Increment lamp column
  if (lampColumn > maxLampColumn) {
    lampColumn = 1;
  g_APinDescription[lampColPin[lampColumnLast]].pPort->PIO_CODR = g_APinDescription[lampColPin[lampColumnLast]].ulPin;              // Turn off previous lamp column
  for (int i = 1; i <= maxLampRow; i++) {                                // Cycle through rows on that column
    if (lampState[lampColumn][i].on) {
      g_APinDescription[lampRowPin[i]].pPort->PIO_SODR = g_APinDescription[lampRowPin[i]].ulPin;
      g_APinDescription[lampRowPin[i]].pPort->PIO_CODR = g_APinDescription[lampRowPin[i]].ulPin;
  g_APinDescription[lampColPin[lampColumn]].pPort->PIO_SODR = g_APinDescription[lampColPin[lampColumn]].ulPin;      // Turn on next lamp column
The issue is I’d like to use the PWM functionality of the pins in question, so is there a method to implement a software-based PWM function in the above routine?
I thought I might use the Timer0 value but I can’t figure out how to access that on the Due.
The PWM frequency is set by a #define in variants.cpp I believe - there are other postings here on changing the Due PWM parameters, a search should throw something up.
The Due has completely different hardware from the Uno/Mega AVR-based controllers.
There are probably some good PWM libraries for Due out there too.
Hopefully future Arduino releases will add a PWM frequency setting function, as this is commonly desired.
