Software Screen Problem
I have a laptop with 3200 x 1800 resolution. The Arduino software for windows 1.6.5-r2 downloaded and install just fine, but the text on the screen is so small I can't read it. Even after I maximize the screen. I have changed the default resolution but it just uses less of the screen, but the text is still just as small.
The program is not scaling correctly. I know just enough to know that is the problem, but not what to do about it. Does anyone have a solution?
Larry
yrralguthrie@yahoo.com
Under the file menu there is a preferences option
the editor font size can be selected there
give it a try :slight_smile:
Thanks, that worked although I had to set the font size to 40! If I don't run across any other issues with scaling, I'm good.
I appreciate the quick help.
Larry
