Software Serial and the BlueSmirf Silver - Weird Characters
I’m having trouble reading serial sent from an Android Bluetooth terminal app. I’m using the SoftwareSerial library so that I can use pins 2 and 3 instead of 0 and 1.
On my breadboard:
BlueSmirf TX—>Arduino 2
BlueSmirf RX—> Arduino 3
BlueSmirf Vcc–> Arduino 5V
BlueSmirf Gnd—> Arduino GND
To keep things simple I’m using the example code from the Software Serial:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(115200);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
Now here’s the weird part - I get only the first letter of anything I send, then gibberish for the remaining characters. For example, if i sent “test” I get “t-­.÷”
If I send “word” I get “w·¹Ù”
Now, if I use this code:
And I re-connect the BlueSmirf RX/TX pins into the Arduino pins 0/1, any text I send from the phone comes over perfectly. Any ideas?
Does anyone have any ideas? Still experiencing the same problems. Thanks.
You are reading ASCII data and sending binary data. Why?
