Software serial - doesn't support parity / stop bit selection?
I am using the Software Serial library to utilise D) - D7 pins as TX, RX for RS232 connectivity.
While this works ok for the main hardware RX,TX pins:
Serial.begin(2400,SERIAL_8N1);
This will not compile for my use of other pins
mySerial.begin(2400,SERIAL_8E1);
error message is:
Arduino: 1.6.5 Hourly Build 2015/06/05 07:12 (Mac OS X), Board: "Arduino Duemilanove or Diecimila, ATmega328"
MBusReader.ino: In function 'void setup()':
MBusReader:22: error: no matching function for call to 'SoftwareSerial::begin(int, int)'
MBusReader.ino:22:31: note: candidate is:
In file included from MBusReader.ino:3:0:
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SoftwareSerial/SoftwareSerial.h:92:8: note: void SoftwareSerial::begin(long int)
void begin(long speed);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SoftwareSerial/SoftwareSerial.h:92:8: note: candidate expects 1 argument, 2 provided
enabled in File > Preferences.
Doesn't want two arguments - not sure why mySerial.begin doesn't inherit this from Serial.begin ?
Which pin is D)?
Of course not. But, since the Arduino, in hardware or software serial, does nothing about parity (errors), the parity setting doesn't matter.
Why should SoftwareSerial inherit from HardwareSerial? The two classes are completely different.
Use a Mega with 4 hardware serial ports.
