Software Serial & hardware serial at the same time
Hi ! I see the Arduino Software Serial Interface , and I make it work . but when I try to use “hardware serial” and “Software Serial” at the same time , only “Software Serial” work , is there somebody can make them work at the same time ? or it is impossibility?
my code:
#include <ctype.h>
#define bit9600Delay 84
#define halfBit9600Delay 42
#define bit4800Delay 188
#define halfBit4800Delay 94
byte rx = 6;
byte tx = 7;
byte SWval;
  pinMode(rx,INPUT);
  pinMode(tx,OUTPUT);
  digitalWrite(tx,HIGH);
  digitalWrite(13,HIGH); //turn on debugging LED
  SWprint('h');  //debugging hello
  SWprint('i');
  SWprint(10); //carriage return
  beginSerial(9600);
void SWprint(int data)
  byte mask;
  //startbit
  digitalWrite(tx,LOW);
  delayMicroseconds(bit9600Delay);
  for (mask = 0x01; mask>0; mask <<= 1) {
    if (data & mask){ // choose bit
     digitalWrite(tx,HIGH); // send 1
    else{
     digitalWrite(tx,LOW); // send 0
  //stop bit
  digitalWrite(tx, HIGH);
int SWread()
  byte val = 0;
  while (digitalRead(rx));
  //wait for start bit
  if (digitalRead(rx) == LOW) {
    delayMicroseconds(halfBit9600Delay);
    for (int offset = 0; offset < 8; offset++) {
     val |= digitalRead(rx) << offset;
    //wait for stop bit + extra
    return val;
    SWval = SWread();
    SWprint(toupper(SWval));
    delay(100);
    printString("hello!");
Hi! I make them work at the same time now! :D the "SWread()" should add a overtime detect.
Cool. Can you post the revised version of the code?
I only read 10 times in Software Serial , if on data come, try next loop, no still wait . these code just fit my purpose .
hope it is useful.
#include <ctype.h>
int flag,i;
byte rx = 6;
byte tx = 7;
byte SWval;
  pinMode(rx,INPUT);
  pinMode(tx,OUTPUT);
  SWprint('i');
  beginSerial(9600);
  flag=0;
  byte mask;
  //startbit
    else{
  //stop bit
int SWread()
  byte val = 0;
  for(i=0;i<10;i++){
    if (digitalRead(rx) == LOW && flag==0) {
      flag=1;
    return val;
  SWval = SWread();
  delay(100);
