Software Serial in v1.07
software serial does not work properly in version 1.07
when connecting it to an actual device it returns "garbage"
the latest working version for the software serial is v1.04
reverting to 1.04 solved the issue
Hi deadpoolcode, which baud rate did you configure? Can you share any (compilable) chuck of code to reproduce the issue?
baud rate is 4800
I am using an example code for GPS readings, working great with version 1.4 but fails with version 1.7
the same is happening every time I am using SoftwareSerial communication
FullExample.ino (4.41 KB)
