// include the SoftwareSerial library so you can use its functions: #include <SoftwareSerial.h>
#define rxPin 3 #define txPin 2
// set up a new serial port
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
byte pinState = 0;
// define pin modes for tx, rx, led pins:
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
// set the data rate for the SoftwareSerial port Serial.begin(9600);
mySerial.begin(9600);
Serial.print("Red Value: ");
// print out the characters:
mySerial.print("$sure r");
mySerial.print(0x0d,HEX);
mySerial.print(0x0a,HEX);
// listen for new serial coming in:
char a = mySerial.read();
char b = mySerial.read();
char c = mySerial.read();
char d = mySerial.read();
char e = mySerial.read(); Serial.print(a); Serial.print(b); Serial.print(c); Serial.print(d); Serial.print(e,DEC); Serial.println();
No matter how I configure this all I seem to retrieve is blank data. Any ideas? Has anyone used this sensor before? Thanks,
Tom
#define rxPin 3
#define txPin 2
byte pinState = 0;
[glow]while ( mySerial.available() < 5 ) ; [/glow]
Serial.print(a);
Serial.print(b);
Serial.print(c);
Serial.print(d);
SoftwareSerial does not have an "available"... but the optional library, NewSoftSerial, no big deal to "install", just copy the folder from the zip to the folder with your other library folders, the ones that came as "standard".... DOES have an "available". Hurrah! Thank you NewSoftSerial authors!!
