Software Serial Library Error
I am trying to add a Bluetooth function into my codes using SoftwareSerial Library but compiling it results into a unfamiliarize compiling error
This is my code:
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h> //i2c pins
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(7, 6);
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))    //clear bit in byte at sfr adress
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))     //set bit in byte at sfr adress
#define seconds() (millis()/1000)  //capture secods
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//pins to use
const int coinPin = 2;
const int button1 = 8, button2 = A0, button3 = 3;
const int relay1 = 10, relay2 = 11, relay3 = 12;
const int button1pushed = 0b00110000;
const int button2pushed = 0b00101000;
const int button3pushed = 0b00011000;
//variables used in the Interrupt Service Routine (ISR) need to be 'volatile'
boolean button1press = false, button2press = false, button3press = false;
volatile long unsigned eventTime;
volatile long unsigned previousEventTime;
volatile long unsigned timeSinceLastEvent;
volatile byte portDstatus;
volatile byte eventFlag0, eventFlag1, eventFlag2, eventFlag3;
//additonal variables
long timeSpent = 0, startTime = 0, coinTimeVal = 60000;
long timeLeft = 0;
long coinCounter = 0;
int event, pulse = 0;
bool event1running = false, event2running = false, event3running =false;
void setup(){
  Serial.begin(9600);//start serial communication
  SoftSerial.begin(9600);
  //define the pins:
  pinMode(button1, INPUT);//define pin as INPUT
  digitalWrite(button1, HIGH);//connect the internal pull-up resistor - this will yield a HIGH readout if the switch is open.
  pinMode(button2, INPUT);
  digitalWrite(button2, HIGH);
  pinMode(button3, INPUT);
  digitalWrite(button3, HIGH);
  pinMode(relay1, OUTPUT);
  digitalWrite(relay1, HIGH);
  pinMode(relay2, OUTPUT);
  digitalWrite(relay2, HIGH);
  pinMode(relay3, OUTPUT);
  digitalWrite(relay3, HIGH);
  //setting up the interrupt: (see chapter 12 in the ATmega328p data sheet for an explanation which register does what etc...)
  cli();
  PCICR |= 0b00000011;    // turn on all ports
  PCMSK0 |= 0b00000001;    // turn on pin PB0, which is PCINT0, pin 8
  PCMSK1 |= 0b00000001;    // turn on pin PC4, which is PCINT12, pin A0
  //PCMSK2 |= 0b00010000;    // turn on pin 4
  sei();
  attachInterrupt(digitalPinToInterrupt(button3), button3event, RISING);
  //lcd init
  lcd.begin(16, 2);
  //coin slot machine
  attachInterrupt(digitalPinToInterrupt(coinPin), coinInterrupt, RISING);
    Serial.print("Coins: ");
    Serial.println(coinCounter);
if(SoftSerial.available()){
    delay(50);
    char c=SoftSerial.read();
    readString+=c;
  if(readString.length()>0){
    Serial.println(readString);
    if (readString =="DRY"){
      if (button1press == false && button2press == false){
  eventTime=millis();//note the time of the ISR call
  eventFlag3=1;//set the event flag that tells the main loop that a button was pressed.
  button3press = true;;
    if (readString =="SOAP"){
      if (button3press == false && button1press == false){
  eventFlag2=1;//set the event flag that tells the main loop that a button was pressed.
   button2press = true;
    if (readString =="WASH"){
      if (button3press == false && button2press == false){
  eventFlag1=1;//set the event flag that tells the main loop that a button was pressed.
  button1press = true;
    readString="";
//  if (eventFlag0 == 1){ //&& (eventTime-previousEventTime<100)){
//      previousEventTime=eventTime;
//      pulse += 1;
//      eventFlag0 = 0;
//      if (not(pulse % 6)){
//        timeLeft += coinTimeVal;
//        pulse = 0;
  if (timeLeft <= 0){
        button1press = false;
        button2press = false;
    if (timeLeft < 0){timeLeft=0;}
    welcomeInsertCoinMessage();
    if (event1running){
      switchRelay(relay1, event1running);
      event1running = !event1running;
    else if (event2running){
      switchRelay(relay2, event2running);
      event2running = !event2running;
    else if (event3running){
      switchRelay(relay3, event3running);
      event3running = !event3running;
  else {
    printTime(timeLeft);
    Serial.println(int(timeLeft/1000));
    if (button1press == true && eventFlag1 == 1 && (eventTime-previousEventTime>100)){
      previousEventTime=eventTime;//note the present event time as last time for the next event
      Serial.println(event1running);
      if (event1running){
        startTime = millis();
        printStatus("Wash...");
      }else{
        printStatus("Washing paused");
      eventFlag1 = 0;//reset the event flag for the next event
    else if (button2press == true && eventFlag2 == 1 && (eventTime-previousEventTime>100)){
      if (event2running){
        printStatus("Soap...");
      }else{
        printStatus("Soap paused");
      eventFlag2 = 0;//reset the event flag for the next event
    else if (button3press == true && eventFlag3 == 1 && (eventTime-previousEventTime>100)){
      if (event3running){
        printStatus("Dry...");
      }else{
        printStatus("Dry paused");
      eventFlag3 = 0;//reset the event flag for the next event
    if (event1running || event2running || event3running){
      //Serial.println("running...");
      timeLeft -= (millis() - startTime);
  }delay(100);
ISR (PCINT0_vect){
ISR (PCINT1_vect){
//ISR (PCINT3_vect){
//  eventTime=millis();//note the time of the ISR call
//  eventFlag3=1;//set the event flag that tells the main loop that a button was pressed.
void button3event(){
void coinInterrupt(){
    coinCounter++;
//  eventFlag0 = 1;
void welcomeInsertCoinMessage(){
    lcd.clear();
    lcd.setCursor(4, 0); //Start at character 4 on line 0
    lcd.print("WELCOME!");
    lcd.setCursor(0, 1);
    lcd.print(" ->Insert Coin<-");
void printTime(long timer){
    long mins, secs, real_sec;
    String t;
    //lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("               ");
    real_sec = timer/1000;
    //mins =(long)(timer/(60*1000));
    mins = real_sec/60;
    secs = real_sec%60;
    Serial.println(secs, mins);
    if (mins > 9 and secs >9){
      t = String("Time  ") + String(mins) + String(":") + String(secs);
    }else if (mins > 9 and secs < 10){
    }else if (mins < 10 and secs > 9){
      t = String("Time  ") + String("0") + String(mins) + String(":") + String(secs);
    }else{
      t = String("Time  ") + String("0") + String(mins) + String(":") + String("0") + String(secs);
    lcd.print(t);
//    delay(100);
//    lcd.setCursor(0, 1);
//    lcd.print(statusAction);
void printStatus(String s){
  lcd.print("               ");
  lcd.print(s);
void switchRelay(int relaynum, bool onOff){
  digitalWrite(relaynum, onOff);
This what the error says
libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_3'
sketch\sketch_jun14a.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_5'
(.text+0x0): multiple definition of `__vector_4'
collect2.exe: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
Yes, that’s correct.
You can’t share interrupt vectors.
There is almost never a reason to use interrupts for button handling. If you check the buttons each time through loop() and don't use delay() for timing you can get rid of your Pin Change interrupts and let SoftwareSerial use them.
This isn't going to work. As soon as the first character arrives the 'readString.length()' is going to be >0. The one character will not equal "DRY", "SOAP", or "WASH" so nothing will be done and 'readString' will be cleared. The same thing will happen for the next character, and the next. You need a way to detect when ALL of the characters have arrived and a way to reset 'readString' when there is no chance that it will ever match. Maybe keep "DRY", "SOAP" and "WASH" in String variables and check to see if at least one of them '.beginsWith(readString)'. If none does, a bad character has arrived and it is time to clear 'readString'.
if (SoftSerial.available())
    char c = SoftSerial.read();
    readString += c;
  if (readString.length() > 0)
    if (readString == "DRY")
    if (readString == "SOAP")
    if (readString == "WASH")
    readString = "";
