Software serial problem -> K-wire without ELM
I`m trying to make a k-wire interface without the elm chip.(it is not av. in my country)
I used this schematic and info fromhttp://blog.perquin.com/blog/category/odbii/.
So, to init the k-wire (fast way) I need to :
  1. Wait for 300ms with K line high.
  2. Pull K line low for 25 +/- 1 ms
  3. Let K line rise high and wait 25ms
  4. init serial connection to 10400 baud, 8N1, 1=0Volt 0=12Volt, least significant bit first
  5. send package c1 33 f1 81 66 33=dest, f1=our tester id, 81=start comms
  6. wait for response 83 f1 01 c1 e9 8f ae 01=physical address, c1=response ok (7f=fail), e9=kb1, 8f=kb2
My idea was
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
void fastinit(){
  Serial.println("F init start");
  digitalWrite(11,HIGH);
  delay(299);//(fast init 300 ms)
  digitalWrite(11,LOW);
  delay(25);
  delay(25);
  mySerial.begin(10400);
  mySerial.write("c1 33 f1 81 66");
  Serial.println("F init end");
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Setup");
  fastinit();
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
For some random reason, i don`t get anything.
Are you sure that that speed is supported?
It's unlikely that the device is expecting a string. Most likely, it is expecting 5 bytes, with values 0xc1, 0x33, etc.
Are you asking if 10400 is supported by the arduino or the K-wire?
Is this how i should send that string?
mySerial.write(0x31);
delay(20);
mySerial.write("next");
//etc?
I'm asking if SoftwareSerial supports that speed.
You shouldn't be sending a string.
byte crap[] = { 0xc1, ox33, 0xf1, 0x81, 0x66 };
mySerial.write(crap, 5);
PaulS:
He needs the 20 ms inter-byte timing for OBDII, so perhaps (using delay())..
  for (int i = 0; i < 5, i++) {
    mySerial.write(crap, i);
I don't see a delay().
PaulS:
You have to squint a bit. Here, I'll enlarge it:
    delay(20);
I don't know why it shrunk so much. :cold_sweat:
Thanks. The bigger font helped.
Any luck ? Did it work ?
