Software Serial Read showing wrong data
I'm using a Nextion display to generate tokens on serial. Different buttons on the display generate a corresponding token.
When I wire the display through an FTDI, the serial data is as expected.
But when I read the display data on SoftwareSerial through the arduino and print it to serial monitor, its not the same data anymore.
So for example, if Button A is generating "1" on toggling, while the display is wired directly through an FTDI, serial monitor shows "1", but through softwareSerial it shows "49"
I intend to use the incoming date with a switch case.
#include <SoftwareSerial.h>
SoftwareSerial nextion(10, 11);
int command;
  nextion.begin (9600);
  if (nextion.available()) {
    int command = nextion.read ();
    Serial.println (command);
    delay (1000);
What is the ASCII value for '1'? Wouldn't happen to be 49, would it? Just so happens that it IS.
Store the value read from the software serial instance in a char, instead of an int, and you'll see different results.
PaulS:
So I remember now the Nextion instruction set did mention that print() outputs as ASCII. Thanks a lot, Paul!
