Software serial reading wrong values
Hi there,
I’m trying to use the software serial library in my arduino Uno to read packets from a ESP8266. I set a constant word packet to test the comms and see if it is working, but it shows a very erratic behavior. Every time a packet is read, the values are different. My arduino code only reads the software serial port and prints it back to the monitor. Code:
#include <SoftwareSerial.h>
SoftwareSerial esp8266(2,3); //TX, RX
esp8266.begin(115200);
String old_msg="";
String data;
//Check to see if anything is available in the serial receive buffer
while (Serial.available()) {
Serial.write(Serial.read());
Also i am using an ESP8266 wifi module thing that is powered from the arduinos 5V
You may have wired things correctly, but the order of pins in the SoftwareSerial constructor is Rx, Tx
So RX is 2 and TX is 3 let me change and see
That code never accesses your esp8266 connection. It only accesses Serial.
Yea i saw that but it dosnt matter i have tried lots of codes before that
The code you post most certainly DOES matter if you expect others to look at it and help solve problems.
So i have changed the code to this:
String old_msg="";
String data;
while (esp8266.available()) {
Serial.write(esp8266.read());
And i have connected esp8266 RX to pin 3 and TX to pin 2 and it still shows messed up data from the char it is reciving from the esp.
And the code running on your esp8266? Configured for 115200 baud as well? I would change that to 9600 baud for softwareSerial...
Wow after letting it run for 2 minutes i see that the data is perfect, thanks a lot for your help!!
