Software serial resetting atmega328p
Deleted
I don’t see in the sketch where watchdog is setup for interrupt mode. If it’s in the fuse, the interrupt is disabled and the reset is enabled,
Deleted
@spaceuino, why have you deleted your posts without any explanation? It is considered very bad manners.
If you have found a solution for your problem then the proper behaviour is to share your solution so that others can benefit from your learning.
...R
