software serial
in Arduino uno the real (RXD,TXD) is The lines(0,1) The Question is: can i define The (RXD,TXD)of Software serial on same lines of Hardware uart: can i write: SoftwareSerial mySerial(0, 1); // RX, TX?????... Thanks 4 u...
what will you achieve from it? Why cant you use 'Serial' instead, which is more efficient.
You can do software serial on the hardware serial pins, but, why would you?
If your question was really "Can I do software serial on the hardware serial pins while also doing hardware serial?", the answer is quite different. That answer is "of course not, don't be silly!"
