I have some good news!
I've got the Arduino Duemillanove board to control and recieve sensor data from the Roomba.
I have tried with and without a buffer (2x Inverter) - and it works, also without!
The problem with the Arduino was the code, it was wrong...
So it is working now, without any modifications to anything, just connected directly to the hardware TX and RX lines on the Arduino.
Here is the working code:
* RoombaBumpTurn
* Implement the RoombaComm BumpTurn program in Arduino
* A simple algorithm that allows the Roomba to drive around
* and avoid obstacles.
* Arduino pin 0 (RX) is connected to Roomba TXD
* Arduino pin 1 (TX) is connected to Roomba RXD
* Arduino pin 2 is conencted to Roomba DD
* Updated 20 November 2006
* - changed Serial.prints() to use single print(v,BYTE) calls instead of
* character arrays until Arduino settles on a style of raw byte arrays
* Created 1 August 2006
* copyleft 2006 Tod E. Kurt <tod@todbot.com>
* http://hackingroomba.com/
int rxPin = 0;
int txPin = 1;
int ddPin = 2;
int ledPin = 13;
char sensorbytes[10];
#define bumpright (sensorbytes[0] & 0x01)
#define bumpleft (sensorbytes[0] & 0x02)
// pinMode(txPin, OUTPUT);
pinMode(ddPin, OUTPUT); // sets the pins as output
pinMode(ledPin, OUTPUT); // sets the pins as output
Serial.begin(57600);
digitalWrite(ledPin, HIGH); // say we're alive
// wake up the robot
digitalWrite(ddPin, HIGH);
delay(100);
digitalWrite(ddPin, LOW);
delay(2000);
// set up ROI to receive commands
Serial.print(128, BYTE); // START
delay(50);
Serial.print(130, BYTE); // CONTROL
delay(50);
digitalWrite(ledPin, LOW); // say we've finished setup
digitalWrite(ledPin, HIGH); // say we're starting loop
updateSensors();
digitalWrite(ledPin, LOW); // say we're after updateSensors
if(bumpleft) {
spinRight();
else if(bumpright) {
spinLeft();
goForward();
void goForward() {
Serial.print(137, BYTE); // DRIVE
Serial.print(0x00,BYTE); // 0x00c8 == 200
Serial.print(0xc8,BYTE);
Serial.print(0x80,BYTE);
void goBackward() {
Serial.print(0xff,BYTE); // 0xff38 == -200
Serial.print(0x38,BYTE);
void spinLeft() {
Serial.print(0x01,BYTE); // 0x0001 == spin left
void spinRight() {
Serial.print(0xff,BYTE); // 0xffff == -1 == spin right
void updateSensors() {
Serial.print(142, BYTE);
Serial.print(1, BYTE); // sensor packet 1, 10 bytes
delay(100); // wait for sensors
char i = 0;
while(Serial.available()) {
int c = Serial.read();
if( c==-1 ) {
for( int i=0; i<5; i ++ ) { // say we had an error via the LED
delay(50);
delay(50);
sensorbytes[i++] = c;
