No, those are the two reliable and working libraries (with many limitations).
Can you tell more about your project ?
Do you use a microcontroller as a Arduino-compatible or a full Arduino board ? Which one ? What is your project ? What are you communicating with. Can you use the default Serial port and upload a sketch via the ICSP and a programmer ? What is your sketch doing ? Why is it important to have more time ? It is a typical beginner's mistake to switch to a faster Arduino board and it does not help because the sketch and the libraries use a lot of delay().
I think that you made a mistake and have to deal with it, but maybe someone else has a good idea.
This class supports the following MCUs: ATtinyx61, ATtinyx4, ATtinyx5, ATmega328P (Pro, UNO, Nano), ATmega32U4 (Micro, Leonardo), ATmega2560 (Mega), ATmega2560RFR2, ATmega1284P and ATmega1286
