Hello sir,
I am using pin change interrupts in arduino leonardo.i got output perfectly…but i need to use software serial library simultaneously in that above code…
just i included library,even i didnt started software serial usage…just compiled code…got below error\
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "C:\Users\Admin\AppData\Local\Temp\arduino_build_479320/pci_softserial_interrupt_overlapping.ino.elf" "C:\Users\Admin\AppData\Local\Temp\arduino_build_479320\sketch\pci_softserial_interrupt_overlapping.ino.cpp.o" "C:\Users\Admin\AppData\Local\Temp\arduino_build_479320\libraries\SoftwareSerial\SoftwareSerial.cpp.o" "C:\Users\Admin\AppData\Local\Temp\arduino_build_479320/core\core.a" "-LC:\Users\Admin\AppData\Local\Temp\arduino_build_479320" -lm
C:\Users\Admin\AppData\Local\Temp\arduino_build_479320\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_9'
C:\Users\Admin\AppData\Local\Temp\arduino_build_479320\sketch\pci_softserial_interrupt_overlapping.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
im attaching my code below…
#include <SoftwareSerial.h>
#include <avr/interrupt.h>
volatile int value = 0;
cli();
PCICR |= 0b00000011; // Enables Ports B and C Pin Change Interrupts
PCMSK0 |= 0b00000001; // PCINT0
sei();
Serial.println(value);
ISR(PCINT0_vect)
value++;
please help me or suggest me solution for this problem
