SoftwareSerial bluetooth causing strange behaviour
Hi guys
I am using an android device to send an angle value (between 0 and 10) via bluetooth and receive that data into arduino via the Genotronex library. Every thing works 100% until I uncomment the Genotronex line right at the bottom of the code. When I do that, the servo suddenly seems to jump, jump, jump etc to some weird value every 100 ms. When this line is commented out, the servo performs correctly and goes 100% to the values I am sending from Android. I just cant see hoe the println of the Genotronex can influence the incoming data???
#include <SoftwareSerial.h>
#include <Servo.h>
SoftwareSerial Genotronex(10, 11);
Servo angle_servo;
int servoPin = 9;
int ledpin=13;
char angle;
int motorPin = 0;
int motorSpeed;
int leftPin = 6;
int rightPin = 7;
String string_c;
  Genotronex.begin(9600);
  angle_servo.attach(servoPin);
  //Serial.begin(9600);
  Genotronex.println("Test Data");
  pinMode(ledpin,OUTPUT);
  pinMode(leftPin,INPUT);
  pinMode(rightPin,INPUT);
  //pinMode(motorPin, INPUT);
  if (Genotronex.available())
    angle = Genotronex.read();
    int temp = angle - 48;
    angle_servo.write(temp * 17);
    motorSpeed = analogRead(motorPin);
    String left = "|0";
    String right = "|0";
    if(digitalRead(leftPin) == HIGH)
     left = ",1";
      left = ",0";
    if(digitalRead(rightPin) == HIGH)
     right = ",1";
      right = ",0";
    string_c = motorSpeed + left + right;
    //Genotronex.println(string_c);
  delay(100);
Thanks for any advice!
Use the Serial instance to debug your program.
Hi guys
After a lot of more research, it turns out that there is a conflict between the Servo and SoftwareSerial libraries and the jittering servo is a well known issue. So I found another Servo library, but now I cant seem to install that one to test :0
Wow, I feel like a noob, but no matter where I put the PWMServo library folder, I get the error PWMServo does not name a type. Here is the library for those who are interrested:
https://github.com/johnmccombs/arduino-libraries/tree/master/PWMServo
