SoftwareSerial interference with my ethernet shield (THINGSPEAK)
I 'am using an Arduino UNO with an ethernet shield, I also have a few sensors which are doing really good and a ThingSpeak channel where I post the sensor information, the problem is that when I use "SoftwareSerial serial gps (7,6)" to initialice my GPS pins the server give me a 404 "Bad request" response, I try with no sending the GPs information but the only think that is bodering here is that line (SoftwareSerial serial gps (7,6)) If I remove it the connection work just fine. I also try with other pins but is just the same. I hear that the ethernet shield maybe use some pins but, again I tried with all the possible combinations.
PLEASE HELP ME!!
The standard Ethernet shield and the Ethernet library uses pins 10, 11, 12, 13 on the Uno.
Reference: https://www.arduino.cc/en/Reference/Ethernet
Great, so in thas case that's not my problem because I use 7 and 6. There is an alternative to SoftwareSerial for an arduino UNO that has only a pair of hardwareserial ?? .
Read this for alternatives to connecting the GPS device. SoftwareSerial is the worst choice.
