SoftwareSerial library won't compile on attiny85
I am trying to use the SoftwareSerial library on an ATtiny85 and when I try to compile the following code:
#include <SoftwareSerial.h>
void setup(){ }
void loop(){ }
I get the following errors:
/Applications/Arduino.app/Contents/Resources/Java/libraries/SoftwareSerial/SoftwareSerial.h:92: error: conflicting return type specified for 'virtual size_t SoftwareSerial::write(uint8_t)'
/Users/oren/Documents/Arduino/hardware/tiny/cores/tiny/Print.h:71: error: overriding 'virtual void Print::write(uint8_t)'
It seems that the header file won't compile properly? Can anyone please provide any help??
Thank you!
You are using a core that does not properly support SoftwareSerial.
Try, Google Code Archive - Long-term storage for Google Code Project Hosting.
