SoftwareSerial receive incorrect format
Hello Sitting and working with a software serial setup.
communication is ok, and in principle, as I receive the correct data, format is just wrong.
Incorrect how.
well it should be understood as.
I sent a request for data.
the device answers.
it looks like that in asci on my serial monitor
AA55001010801050444C333230303132313230393033365D
It should just look like this in HEX
0XAA, 0X55, 0x00 etc.->
what is missing??
#include <SPI.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
char sporg_serie_nummer[22]={
  0xAA,0x55,0x01,0x00,0x00,0x00,0x10,0x00,0x00,0x01,0x10,0xAA,0x55,0x01,0x00,0x00,0x00,0x10,0x04,0x00,0x01,0x14};
char serienummer_tel=0x00;
char i;
int incomingByte = 0;
  mySerial.begin(9600);//115200
  while (serienummer_tel<22)
    mySerial.print(sporg_serie_nummer[serienummer_tel]);
    serienummer_tel++;
  i=0;
  while(i<27) {
    if (mySerial.available()>0){
      incomingByte = mySerial.read();
      Serial.print(incomingByte,HEX); //I have tried various solutions here but it was not right
      i++;
Best Kim Jessen
If a particular variable is hex, then always use hex with it. If it's a normal number - this seems to be used as a counter - then don't mix hex and normal numbers. By initialising it to a hex number, nobody (including you) can be sure if you really meant to write 0x22 on the second line.
The HEX formatting in Serial.print() doesn't pad the leading zeros. Numbers 0x00 to 0x0F will be printed as 0-F and not 00-0F as you might expect.
      if(incomingByte<0x10) Serial.print('0');
"Quote
Code: [Select]
If a particular variable is hex, then always use hex with it. If it's a normal number - this seems to be used as a counter - then don't mix hex and normal numbers. By initialising it to a hex number, nobody (including you) can be sure if you really meant to write 0x22 on the second line."
Yes you are right my mistake.
for the case!
I think you misunderstand what is happening.
I know 100% sure that the unit is transmitting a series of HEX values.
0xAA,0x55,0x00,0x10,0x10,0x80,0x105,0x04,0x44,0xC3,0x33,0x23,0x03,0x03,0x13,0x23,0x13,0x23,0x03,0x93,0x03,0x33,0x65
But I receive it as SCIT values
in ascites I expected to receive this:
UPDL3200121209036]
right now I solved it by loading that coming in into an array.
