SoftwareSerial resets arduino pro mini
Hi Guys,
I’m working on a project which involves a zigbee and ir leds
i have a zigbee hooked up to my arduino pro mini over softwareserial (4,5)
Problem : first time when i send 7 bytes over zigbee the everything works fine but second time when i send the 7 bytes i get acknowledgement that it received 7 bytes but the data it read is empty. third time no response after 4 or 5 try the pro mini resets. I tried changing pins to 10,11 but still the same problem.
i want the program to work every time i send the 7 bytes.
Thanks in advance for the help :slight_smile:
#include <IRremote.h>
#include <SoftwareSerial.h>
int gma=0;
#define DID_H 0x54
#define DID_L 0xF1
int px = 0;
int khz = 38; // 38kHz carrier frequency for the NEC protocol
unsigned int onoff[] = {8700,4400,550,1600,550,1600,550,550,500,550,500,550,500,550,500,550,500,1650,500,550,550,1600,550,1600,550,550,500,550,500,550,500,550,500,550,500,550,500,550,500,1650,550,500,550,500,500,550,550,500,550,500,500,550,550,1600,550,550,500,550,500,550,500,1600,550,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500}; //AnalysIR Batch Export (IRremote) - RAW
unsigned int up[] = {8750,4350,600,1550,550,1650,500,550,500,550,500,550,500,550,500,550,500,1650,550,500,550,1600,550,1650,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,1650,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,550,500,500,550,550,500,550,500,550,500,550,500,550,500,500,550,550,500,550,500,550,500,550};
SoftwareSerial zb(4,5);
IRsend irsend;
  zb.begin(38400);
  delay(5000);
  zb.print("AT+SETPANID 3301");
   for(int l=0;l<=100;l++)
    zb.read();
    delay(10);
  zb.listen();
  if(zb.available()==7)
    if(gma==1)
      zb.print("READ OK");
    byte inc[7];
    bool xmp = false;
    for(int i=0;i<=7;i++)
      inc[i] = zb.read();
    zb.write(inc,sizeof(inc));
    byte crc=0x00;
    for(int i=0;i<=5;i++)
       crc = crc ^ inc[i];
    if(crc == inc[6])
      xmp = true;
      xmp = false;
    if((inc[0]==0xAF)&&(inc[1]==0x1F)&&(xmp==true))
      if((inc[2]==DID_H)&&(inc[3]==DID_L))
        if(inc[4]==0x11)
          execute(inc[5]);
void execute(byte cmd)
  if(cmd == 0x11)
    irsend.sendRaw(onoff, sizeof(onoff) / sizeof(onoff[0]), khz);
    ACK();
  else if(cmd == 0x16)
    irsend.sendRaw(up, sizeof(up) / sizeof(up[0]), khz);
    ACK();
    NAK();
  gma = 1;
  readh();
void ACK()
  byte ack[6];
  ack[0] = 0xAF;
  ack[1] = 0x1F;
  ack[2] = DID_H;
  ack[3] = DID_L;
  ack[4] = 0x22;
  ack[5] = 0xAA;
  byte crc = 0x00;
    crc ^= ack[i];
  ack[6] = crc;
  zb.write(ack,sizeof(ack));
void NAK()
  byte ack[6];
  ack[0] = 0xAF;
  ack[1] = 0x1F;
  ack[2] = DID_H;
  ack[3] = DID_L;
  ack[4] = 0x22;
  ack[5] = 0xFF;
  byte crc = 0x00;
    crc ^= ack[i];
  ack[6] = crc;
void getdata()
 while(zb.available()>0)
  zb.write(zb.read());
void readh()
   for(int l=0;l<=50;l++)
    zb.read();
    //delay(2);
Images from Original Post so we don’t have to download them. See this Image Guide
…R
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. Notice how they don't rely on delay().
It would be a big help if you could describe how your program is supposed to work - i.e. a walk-through of the code.
The data you send in ACK and NAK looks like it could be figured out while you are writing the program and included as a pre-defined byte array
...R
You are overwriting the array here:
    byte inc[7];
    bool xmp = false;
      inc[i] = zb.read();
I think you want:
    byte inc[7];
    bool xmp = false;
    for(int i=0;i<7;i++)
      inc[i] = zb.read();
In my opinion you should use a "bloking" condition before every read()
Example: While serial.available()==0{}
It would block your code until there are data coming from your serial device I also suggest to add a timeout, if you need more help write
Thanks for pointing that out , I changed it but the problem still exists.
Robin2: Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. Notice how they don't rely on delay().
...R
The incoming data is 7 bytes
Byte 1 = 0xAF -- Header Byte 2 = 0x1F -- Header Byte 3 = DID_H -- Device ID High byte Byte 4 = DID_L -- Device ID Low Byte Byte 5 = 0x11 -- Direction - 0x11 is server to client - 0x22 is client to server Byte 6 = CMD -- commands (see function execute in the code) Byte 7 = CRC -- bytes 1 to 6 Xor'd - this is to check if incoming data is valid
the arduino pro mini receives the 7 bytes -> executes the command -> sends ACK
if the command is not in the list it sends NAK
the data is structured this way because if i wanted to add another device on the network this will allow me to add it
Thanks
Check the rest of your code for the same issue - I found two more.
void ACK()
  byte ack[6];
  ack[0] = 0xAF;
  ack[1] = 0x1F;
  ack[2] = DID_H;
  ack[3] = DID_L;
  ack[4] = 0x22;
  ack[5] = 0xAA;
  byte crc = 0x00;
    crc ^= ack[i];
  ack[6] = crc;                        // <=== overflow
void NAK()
  byte ack[6];
  ack[0] = 0xAF;
  ack[1] = 0x1F;
  ack[2] = DID_H;
  ack[3] = DID_L;
  ack[4] = 0x22;
  ack[5] = 0xFF;
  byte crc = 0x00;
    crc ^= ack[i];
Thank you very much
This fixed my problem :slight_smile:
aster94:
In my opinion you should use a “bloking” condition before every read()
I presume you mean “blocking”
There should be NO blocking code anywhere in an Arduino program.
…R
