SoftwareSerial with multiple RFID antennas.. problem
Hi everyone.
Im working with 4 RFID antennas, and im trying to read the ID send by them with SoftwareSerial library (but it's not working).
If i use just 1 Antenna, it works fine with these library, but not with 2 antennas... I try using port.listen(), and the antennas have a separeted transformer 5V 2Amps.
Here's my code if there anyone who could help... i'll appreciated (Hlp pliiiizzz)... :stuck_out_tongue:
#include <SoftwareSerial.h>
SoftwareSerial SerialUno(10, 11);
SoftwareSerial SerialDos(12, 13);
SoftwareSerial SerialTres(6, 7);
char incomingByte = 0; // for incoming serial data
byte storedCard[6]; // Stores an ID read from EEPROM
byte readCard[6]; // Stores an ID read from the RFID reader
byte checksum = 0; // Stores the checksum to verify the ID
byte bytesread = 0;
byte i = 0;
int val = 0;
byte tempbyte = 0;
char IDstring[13];
//Register your RFID tags here
char tag1[13] = "4300F97F21E4"; //Rodrigo
char tag2[13] = "4300F9C60E72"; //Gabriela
char tag3[13] = "030034E42AF9"; //Borrador
char tag4[13] = "0300346585D7"; //Maestro
//char tag5[13] = "030034DBA448";
int ledRojo = 8;
int ledVerde = 9;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
pinMode(10, INPUT);
pinMode(12, INPUT);
pinMode(11, OUTPUT);
pinMode(13, OUTPUT);
pinMode(ledRojo, OUTPUT); // Initialize LED pin
pinMode(ledVerde, OUTPUT); // Initialize LED pin
digitalWrite(ledRojo, LOW);
digitalWrite(ledVerde, LOW);
revisarEntrada();
revisarSalida();
//revisarUno();
//revisarDos();
void revisarEntrada()
SerialUno.begin(9600);
byte val = 0; // Temp variable to hold the current byte
// send data only when you receive data
if (SerialUno.available() > 0)
//SerialUno.listen();
if((val = SerialUno.read()) == 2) // First Byte should be 2, STX byte
// getID(); Get the ID, sets readCard = to the read ID
// 5 HEX Byte code is actually 10 ASCII Bytes.
while ( bytesread < 12 ) // Read 10 digit code + 2 digit checksum
if( SerialUno.available() > 0) // Check to make sure data is coming on the serial line
val = SerialUno.read(); // Store the current ASCII byte in val
if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02))
{ // If header or stop bytes before the 10 digit reading
break; // Stop reading
IDstring = val;
  • i++;*
  • if ( (val >= '0' ) && ( val <= '9' ) ) // Do Ascii/Hex conversion*
  • val = val - '0';*
  • else if ( ( val >= 'A' ) && ( val <= 'F' ) )*
  • val = 10 + val - 'A';*
  • Serial.print(val,HEX);*
  • Serial.print(" ");*
  • if ( bytesread & 1 == 1 ) // Every two ASCII charactors = 1 BYTE in HEX format*
  • // Make some space for this hex-digit by*
  • // shifting the previous hex-digit with 4 bits to the left:*
  • readCard[bytesread >> 1] = (val | (tempbyte << 4));*
  • if ( bytesread >> 1 != 5 ) // If we're at the checksum byte,*
  • checksum ^= readCard[bytesread >> 1]; // Calculate the checksum using XOR*
  • else // If it is the first HEX charactor*
  • tempbyte = val; // Store the HEX in a temp variable*
  • bytesread++; // Increment the counter to keep track*
  • bytesread = 0;*
  • i=0;*
  • Serial.println();*
  • Serial.println(IDstring);*
  • checkTag(IDstring); //Check if it is a match*
  • else*
  • checksum = 0;*
    void revisarSalida()
  • SerialDos.begin(9600);*
  • byte val = 0; // Temp variable to hold the current byte*
  • // send data only when you receive data*
  • if (SerialDos.available() > 0)*
  • //SerialDos.listen();*
  • if((val = SerialDos.read()) == 2) // First Byte should be 2, STX byte*
  • // getID(); Get the ID, sets readCard = to the read ID*
  • // 5 HEX Byte code is actually 10 ASCII Bytes.*
  • while ( bytesread < 12 ) // Read 10 digit code + 2 digit checksum*
  • if( SerialDos.available() > 0) // Check to make sure data is coming on the serial line*
  • val = SerialDos.read(); // Store the current ASCII byte in val*
  • if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02))*
  • { // If header or stop bytes before the 10 digit reading*
  • break; // Stop reading*
    _ IDstring = val;_
    * i++;*
    * if ( (val >= '0' ) && ( val <= '9' ) ) // Do Ascii/Hex conversion*
    * val = val - '0';*
    * else if ( ( val >= 'A' ) && ( val <= 'F' ) )*
    * val = 10 + val - 'A';*
    * Serial.print(val,HEX);*
    * Serial.print(" ");*
    * if ( bytesread & 1 == 1 ) // Every two ASCII charactors = 1 BYTE in HEX format*
    * // Make some space for this hex-digit by*
    * // shifting the previous hex-digit with 4 bits to the left:*
    * readCard[bytesread >> 1] = (val | (tempbyte << 4));*
    * if ( bytesread >> 1 != 5 ) // If we're at the checksum byte,*
    * checksum ^= readCard[bytesread >> 1]; // Calculate the checksum using XOR*
    * else // If it is the first HEX charactor*
    * tempbyte = val; // Store the HEX in a temp variable*
    * bytesread++; // Increment the counter to keep track*
    * bytesread = 0;*
    * i=0;*
    * Serial.println();*
    * Serial.println(IDstring);*
    * checkTag(IDstring); //Check if it is a match*
    * else*
    * checksum = 0;*
    // If the serial port is ready and we received the STX BYTE (2) then this function is called
    // to get the 4 BYTE ID + 1 BYTE checksum. The ID+checksum is stored in readCard[6]
    // Bytes 0-4 are the 5 ID bytes, byte 5 is the checksum
    //void getID()
    void checkTag(char tag[])
    * int actuador;*
    * //Check the read tag against known tags*
    * if(strlen(tag) == 0) return; //empty, no need to contunue*
    * if(compareTag(tag, tag1)){ // if matched tag1, do this*
    * Serial.println("Usuario: Rodrigo");*
    * actuador=1;*
    * }else if(compareTag(tag, tag2)){ //if matched tag2, do this*
    * Serial.println("Usuario: Gabriela");*
    * actuador=1; *
    * }else if(compareTag(tag, tag3)){*
    * Serial.println("Tarjeta: Borrado");*
    * actuador=2; *
    * }else if(compareTag(tag, tag4)){*
    * Serial.println("Tarjeta: Maestro");*
    * actuador=2;*
    * }else{*
    * Serial.print("Tarjeta Desconocida: ");*
    * Serial.println(tag); //read out any unknown tag*
    * actuador=3; *
    * if(actuador==1)*
    * digitalWrite(ledVerde, HIGH);*
    * else if (actuador==2)*
    * digitalWrite(ledRojo, HIGH);*
    * digitalWrite(ledVerde, HIGH); *
    * else if (actuador==3)*
    * delay(100);*
    boolean compareTag(char one[], char two[])
    //compare two value to see if same,
    //strcmp not working 100% so we do this
    * if(strlen(one) == 0) return false; //empty*
    * for(int i = 0; i < 12; i++){*
    if(one != two*) return false;*
    * return true; //no mismatches*
Please modify your post. Select all the code. Then press the icon with the # on it. Then save the changes. The code is unreadable as is.
What version of the IDE are you using? Have you read the note about only being able to use one instance of NewSoftSerial (called SoftwareSerial on 1.0) at a time?
