SoftwareSerial wrapper class problem!!!
Hello guys,
I created custom classes for my bluetooth and wi-fi modules each with SoftwareSerial data field.
After that i create two objects from these classes, and i call initialize function for each of them.
First i initialize wifi and after that bluetooth, and here comes the problem. I can read only from bluetooth wrapper object. If i changed initializing order first bluetooth after that wifi, read is available only for wifi.
Here is my code with only basics.
class SoftwareSerial;
class Wifi {
public:
** Wifi ();**
** ~Wifi ();**
** void initialize();**
private:
SoftwareSerial* wifi_serial;
Wifi::Wifi ()
Wifi::~Wifi ()
** delete wifi_serial;**
void Wifi::initialize (const int speed_serial)
** wifi_serial = new SoftwareSerial(PIN_WIFI_RX, PIN_WIFI_TX);**
** pinMode(PIN_WIFI_TX, OUTPUT);**
** digitalWrite(PIN_WIFI_TX, HIGH);**
** wifi_serial->begin(speed_serial);**
class Bluetooth {
public:
** Bluetooth ();**
** ~Bluetooth ();**
private:
SoftwareSerial* bluetooth_serial;
Bluetooth::Bluetooth ()
Bluetooth::~Bluetooth ()
** delete bluetooth_serial;**
void Bluetooth::initialize (const int serial_speed)
** bluetooth_serial = new SoftwareSerial(PIN_BTH_RX, PIN_BTH_TX);**
** pinMode(PIN_BTH_TX, OUTPUT);**
** digitalWrite(PIN_BTH_TX, HIGH);**
** bluetooth_serial->begin(serial_speed);**
So... i created two instance from each class
Bluetooth bluetooth;
Wifi wifi;
void setup ()
bluetooth.initialize();
wifi.initialize();
In this case only wifi is available for read.
If order is changed like this
void setup ()
wifi.initialize();
Now i can read only from bluetooth.
Please someone to explain where i am wrong.
Does this help ? http://forum.arduino.cc/index.php?topic=113666.0
Yes, thank you. I found my problem. SoftwareSerial.listen() function.
I found my problem.
That may be one of your problems.
Another one, though, is assuming that new actually returned a valid pointer. Another one is assuming that the pointer passed to delete is actually valid.
Neither assumption is necessarily valid.
why are you dynamically allocating them anyway?
