SoftwareSerial
Hi All,
I’m receiving data (AV voltage readings) from Nano to an ESP8266, running perfectly.
Now when I’m putting all together, I’m seeing individual chars.
I’m showing it to an TFT and also reading data from a BME280 without problems too.
The first and second Attachment are the serial readings. The third is when I’m trying to put all together.
So, I’m wondering if you could guide me with the best way to solve this.
Thanks!
SERIAL_SERIAL_Nano.ino (1.08 KB)
SERIAL_SERIAL_ESP.ino (565 Bytes)
BME280_and_AC readings_to_TFT.ino (3.97 KB)
Read the “Read this…” about using </> code tags to post your code.
So, I'm wondering if you could guide me with the best way to solve this.
Solve what? It is not clear, to me at least, what the problem is.
And I agree with Nick_Pyner that you should read the how to use this forum sticky. Not only will you see how to post code so that all members can see it, but there is good advice on how to ask a good question.
