I'm trying to control 2 servos with an ATTiny85 (IO 3 & 4). I face a problem with my program or with the ATTiny85 or with the SoftwareServo lib or with the servos.
The problem is that one servo is doing what he want, not what I say
- No problem with the servos, I can switch them, the problem is switch from servos
- No problem with the ATTiny, same code on Arduino = same pb
- Don't think it can come from the lib, google don't find similar problems
- It can only comes from my code... but after many rewrites, I don't find solutions...
Here is my code (for Arduino) :
//#include <TinyWireS.h>
#include <SoftwareServo.h>
// Define hardware
#define SERVO_H_PIN 3
byte SERVO_H_LIMITS[2] = {0, 180}; // set limitations (min/max: 0->180)
#define SERVO_V_PIN 4
byte SERVO_V_LIMITS[2] = {80, 100}; // set limitations (min/max: 0->180)
#define SERVO_MIN_STEP 1
#define SERVO_MAX_STEP 10
#define LED_LASER_PIN 13
// Define software
#define I2C_Address 7
SoftwareServo servo_h;
float servo_h_position = SERVO_H_LIMITS[0];
float servo_h_target = (SERVO_H_LIMITS[1] - SERVO_H_LIMITS[0]) / 2;
SoftwareServo servo_v;
float servo_v_position = SERVO_V_LIMITS[0];
float servo_v_target = (SERVO_V_LIMITS[1] - SERVO_V_LIMITS[0]) / 2;
delay(100);
// Attach pins
pinMode(LED_LASER_PIN, OUTPUT);
servo_h.attach(SERVO_H_PIN);
servo_v.attach(SERVO_V_PIN);
// Init pins
servo_h.write(servo_h_position);
servo_v.write(servo_v_position);
for(byte i=0;i<10;i++) {
SoftwareServo::refresh();
delay(20);
// Init I2C
//TinyWireS.begin(I2C_Address); // Begin I2C Communication
//TinyWireS.onRequest(onRequestCallback); // When requested, call function transmit()
// Init is over
blinkLed(LED_LASER_PIN, 4, 1500);
if(servo_h_position != servo_h_target || servo_v_position != servo_v_target) {
if(servo_h_position != servo_h_target) {
int diff = abs(servo_h_target - servo_h_position);
byte stepSize = min(diff, SERVO_MIN_STEP) * (servo_h_target - servo_h_position) / diff;
servo_h_position += stepSize;
if(servo_v_position != servo_v_target) {
int diff = abs(servo_v_target - servo_v_position);
byte stepSize = min(diff, SERVO_MIN_STEP) * (servo_v_target - servo_v_position) / diff;
servo_v_position += stepSize;
delay(20);
void onRequestCallback() {
// Action methods
void blinkLed(byte ledPin, byte nbTimes, int duration) {
int waitTime = duration / (nbTimes * 2);
for(byte i=0; i < nbTimes; i++) {
digitalWrite(ledPin, HIGH);
delay(waitTime);
digitalWrite(ledPin, LOW);
delay(waitTime);
Do you find anything strange ? Did you already face a problem with SoftwareServo lib and many Servos ?
I really need some help on this topic !
Thanks
