hi there,all...in this project i use ESP32 as receiver data from uno.here,i am using RX,TX in ESP32 at pin 16 and 17 and make it global .but i want calling it in another finction but by its inilitation name.i try to use SofwareSerial and declare at pin 16(Rx),and (17(Tx). and sudenly this problem happen.how to solve this?.........i think there is no mistake when i declare UART pin with SofwareSerial.
this is my code:
//#define RXp2 16
//#define TXp2 17
#include <WiFi.h>
#include <SoftwareSerial.h>
// membaca pinout RX,Tx
SoftwareSerial Seriala2(16, 17);
//#include "CTBot.h"
////variabel untuk bot telegram
//CTBot myBot;
////konfigurasi koneksi ke wifi
//const char* ssid = "Ngaji sam";
//const char* pass = "dikunci1";
////variabel token id telegram
//String token =
String dataIn;
String dt[10];
int i;
int rpm = 0;
float cadence = 0;
float Odo = 0;
float Trip = 0;
float Speed = 0;
float torsi = 0;
float batt = 0;
float TripNow = 0;
float OdoNow = 0.0;
boolean parsing=false;
float keliling = 1.57;
int a;
int b;
float c;
int d;
float e;
float f;
Seriala2.begin (9600, SERIAL_8N1, 16, 17);
dataIn="";
///////////////////////telegram bot/////////////////////
// Serial.println("memulai telegram bot koneksi ke wifi");
////koneksi ke wifi
//myBot.wifiConnect(ssid,pass);
////set token telegram
//myBot.setTelegramToken(token);
////cek koneksiwifi
//if(myBot.testConnection())
// Serial.println("koneksi berhasil");
// else
// Serial.println("koneksi gagal");
//////////////////**LOOPING PROGRAM!!*//////////////////////////
// Serial.println("Message Received: ");
if(Seriala2.available()>0) {
char inChar = (char)Seriala2.read();
dataIn += inChar;
if (inChar == '\n') {
parsing = true;
if(parsing){
parsingData();
parsing=false;
dataIn="";
// Serial.println(Seriala2.readString());
void serialtersedia(){
//////////************ PARSING DATA***********//////////////////
void parsingData(){
int j=0;
//kirim data yang telah diterima sebelumnya
Serial.print("data masuk : ");
Serial.print(dataIn);
Serial.print("\n");
//inisialisasi variabel, (reset isi variabel)
dt[j]="";
//proses parsing data
for(i=1;i<dataIn.length();i++){
//pengecekan tiap karakter dengan karakter (#) dan (,)
if ((dataIn[i] == '#') || (dataIn[i] == ','))
//increment variabel j, digunakan untuk merubah index array penampung
j++;
dt[j]=""; //inisialisasi variabel array dt[j]
//proses tampung data saat pengecekan karakter selesai.
dt[j] = dt[j] + dataIn[i];
a = dt[0].toInt();
b = dt[1].toInt();
c = dt[2].toFloat();
d = dt[3].toInt();
e = dt[4].toFloat();
f = dt[5].toFloat();
rpm = d / 360;
cadence = b / 1920;
batt = ((f*0.00489)*16.03);
Speed = rpm * keliling * 3.6 / 60; //Sudah KM/H
Trip = d / 6 * keliling / 1000 / 3600;
TripNow = TripNow + Trip;
OdoNow = OdoNow + Trip;
torsi = c / 3.3 * 80;
//kirim data hasil parsing
//Serial.print("PWM Motor : ");
//Serial.println(dt[0].toInt());
//Serial.print("\n");
//Serial.print("pedal count : ");
//Serial.print(dt[1].toInt());
//Serial.print("torsi pedal : ");
//Serial.print(dt[2].toFloat());
//Serial.print("\n\n");
//Serial.print("Kecepatan : ");
//Serial.print(dt[3].toInt());
//Serial.print("Arus baterai : ");
//Serial.print(dt[4].toInt());
//Serial.print("Voltase baterai : ");
//Serial.print(dt[5].toInt());
//delay(1500);
this is an error in arduino monitor.:
this is my error massage:
Compiling sketch...
"C:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\ridho\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IC:\\Users\\ridho\\Documents\\Arduino\\libraries\\EspSoftwareSerial\\src" "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_119365\\sketch\\esp32_reciever.ino.cpp" -o "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_119365\\sketch\\esp32_reciever.ino.cpp.o"
C:\Users\ridho\Documents\Arduino\esp32_reciever\esp32_reciever.ino: In function 'void setup()':
esp32_reciever:40:43: error: invalid conversion from 'int' to 'SoftwareSerialConfig' [-fpermissive]
In file included from C:\Users\ridho\Documents\Arduino\esp32_reciever\esp32_reciever.ino:5:0:
C:\Users\ridho\Documents\Arduino\libraries\EspSoftwareSerial\src/SoftwareSerial.h:110:10: note: initializing argument 2 of 'void SoftwareSerial::begin(uint32_t, SoftwareSerialConfig, int8_t, int8_t)'
void begin(uint32_t baud, SoftwareSerialConfig config,
Multiple libraries were found for "WiFi.h"
Used: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries\WiFi
Using library WiFi at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library EspSoftwareSerial at version 6.12.6 in folder: C:\Users\ridho\Documents\Arduino\libraries\EspSoftwareSerial
exit status 1
thanks
megantara
