Soil Moisture Sensor Output 7-Segment Display
Can you program arduino to have the output from the soil moisture sensor to a seven segment display? Needed for a project. :confused:
Very plausible. Google garduino to see some projects where soil moisture is measured. Google should get you a solution to the seven segment display pretty easily too.
Thank you for your help! Will do! :)
