Hello,
A while back i asked a question how to make a soil sensor. I made a level control and the whole project and everything worked as planned.
I knew of the corroding part but my question is.
I set a interval of 3 hours to read the soil moisture.
does the analog pin keep sending eletricity to the sensor constantly, or only in my loop?
can anyone check out my code?
If it is sending power constantly to the sensor is there a way to stop it?
thx in advance
int moisture = analogRead(A0); // Analoge ingang 0 VOCHTMETING
int levelValue = analogRead(A1); // Analoge ingang 1 LEVELMETING
int stayON = 15000; // AANTAL SECONDEN DAT DE RELAIS AAN MOET STAAN
void setup() // Hier begint de installatie
Serial.begin(9600); // De communicatie met de seriële poort wordt gestart. Dit vereist dat u de waarde te lezen in de seriële monitor.
pinMode (6,OUTPUT); //RELAIS WERKING
pinMode (8,OUTPUT); //OUTPUT 8 IS RODE LED
pinMode (9,OUTPUT); //OUTPUT 9 IS ORANJE LED
pinMode (10,OUTPUT); //OUTPUT 10 IS GROENE LED
pinMode (11,OUTPUT); //LEVEL GOED: GROENE LED
pinMode (12,OUTPUT); //LEVEL SLECHT : RODE LED
void loop() // Hier begint de volledige loop
Serial.print("level : "); // Naam die we kunnen zien op de seriele monitor waar we de waarden kunnen aflezen
Serial.println(levelValue); // Verwijzing voor verderecodering
if (400>levelValue ) // ONDER DE 400 GAAT DIT IN WERKING
digitalWrite (11, LOW); //GROENE LED AAN
digitalWrite (12, HIGH); //RODE LED UIT
digitalWrite (6, HIGH); // RELAIS UIT
digitalWrite (11, HIGH); // GROENE LED UIT
digitalWrite (12, LOW); // RODE LED AAN
Serial.print("Vochtigheidsmeter : ");
Serial.println(moisture);
if (moisture <=149 && 400>levelValue) // ONDER DE 149 VOCHTIGHEID EN ALS HET LEVEL IN ORDE IS GAAT DIT INWERKING
digitalWrite(10, HIGH); // GROENE LED UIT
digitalWrite(8, LOW); // RODE LED AAN
digitalWrite(6, LOW); // Relais AAN
delay(stayON); // AAN GEDURENDE DE AANTAL MS DIE VANBOVEN INGESTELD STAAN
digitalWrite(6, HIGH); // DAN RELAIS UIT
if (moisture <=149) // ONDER DE 149 VOCHTIGHEID EN ALS HET LEVEL IN ORDE IS GAAT DIT INWERKING
digitalWrite (8, HIGH); // RODE LED UIT
if (moisture < 300 && moisture >149) //TUSSEN 149 EN 300 GAAT DIT IN WERKING
digitalWrite (9, LOW); // Oranje LED
digitalWrite (9, HIGH);
if (moisture >=300) // Green LED
digitalWrite (10, LOW);
digitalWrite (10, HIGH);
delay(7200000); //7200000 seconden of 2 uur
