Soil Moisture Values
Hello,
does anyone know the value of wet, dry soil?
:o :o
wet = 0 dry = 1
The more information you give the better answer you can expect.
A better answer is it really depends on the way you measure the moisture. And what sensortype.
So please tell more about the project, the sensor you use, hardware schema etc.
You can fill a pos with sand and make a measurement. add 1 cc of water and test again add 1 cc of water and test again ....
After a few dozen measurements you have the data for a lookup table (assuming an analog sensor)
No.
Try it for yourself.
It depends on the sensor, your specific soil type, and your definitions of both "wet" and "dry".
frazao_33: Hello,
:o :o
dry soil is lighter per cm3 than wet soil - at least for top soil
