Soil Moisture
Hello All.
Im a bit of a newb to electonics but realy enjoying it. Im a little stuck with a soil moisture sensor that I bought.
I have the VVC on the sensor connected to 5v, the GND to ground on the Arduino UNO. Ive tried both the analogue and digital pins simultaneously and independently. I wrote a simple sketch that just displays the values in the serial monitor. However I cant get my value to change, it stays the same weather the probe is in water or thin air.
Do I have a dudd?
Is there any way I can test, other than what I have done, perhaps with my multimeter or something?
Here's the sketch.
int wetRead = A0;
int ledPin = 13;
int digRead = 3;
pinMode(13, OUTPUT);
pinMode(wetRead, INPUT);
pinMode(digRead, INPUT);
int wetNum = analogRead(wetRead);
int digval = digitalRead(digRead);
delay(100);
Serial.println(wetRead);
Serial.println(digval);
Without any information regarding the sensor, we can't really help you.
What are the sensors outputs ? What values does your sketch output ?
It is also possible that using the analog pin requires you to pull up or down the digital pin.
What does the datasheet say ?
Regardless of that, you can drop your first two delay() in your loop(). They are practically useless.
