Hi does any one know how I can take a voltage reading from a small solar cell to an arduino uno. I then want to display it on LabVIEW. Any help appreciated.
What is the maximum voltage produced by the solar cell in very bright sunlight?
If it exceeds 5v then you need a pair of resistors as a voltage divider to get a range with a max of 5v or a little less. Then any of the analog pins can measure the 0-5v voltage and give you a number. Use some maths to adjust that number to the actual voltage range.
...R
