They specify test conditions and I believe that spec.
It is nearly four times bigger than yours.
I would not expect more than a watt from the panels you have.
Do these solar panels have diodes built in for 1 way charging or can they feedback?
A:
The cells do not appear to have any external components. They do not have any wires either. The front surface is coated with a thin rigid clear material. The rear surface has solder terminals. I have installed them in an outdoor application about a month ago (july 2014) and they are still functioning as expected. Each of my cells is driving a network of 4 microprocessors. In full sun typically they output about 200 ma @5.1 volts. With sun behind a dense cloud, the output current drops to about 60 ma @ 2.2 volts. see less
john king answered on August 21, 2014
The voltage rating on solar panels is usually that attained at rated current in full sunlight. If you test the voltage, open circuit in full sunlight you will get a voltage well above the rated voltage. My 12 volt 10w panels produce 21 volts open circuit, which is pretty normal. The voltage drops off rapidly as the load increases. The obvious answer lies in putting a regulator on the output to get a steady voltage. A switched mode regulator should be used as linear ones would be too inefficient. The exception may be if the solar panel output voltage is too close to the voltage required by the device to be charged. In this case a LDO regulator or better still a SEPIC type unit (buck/boost) could be used. (e.g. ZnDiy-BRY XD-82B 12V Storage Battery Power Indicator Module w/ 4 LEDs - Deep Blue - Free shipping - DealExtreme or DC-DC Converter Auto Step-Up Step-Down Solar Power Supply Module - Red - Free shipping - DealExtreme)
However, the above is fairly moot, unless your current draw is very small, as the panel voltage drops off very very rapidly once the current draw approaches the short circuit current rating of the panel. There is an excellent article on the phenomenon on Adafruit: Design Notes | USB, DC & Solar Lipoly Charger | Adafruit Learning System with some explanatory graphs.
Consequently, if you are drawing more than a small amount of current you will get rapid oscillations as the voltage drops; regulator drops out; voltage rises; regulator cuts in; load rises; voltage drops; regulator drops out, etc.
To get the best efficiency (or merely to get it to work with small panels like yours) you need something to control the current draw dynamically (and quickly) to deal with variations such as clouds passing over and to optimise the panels output automatically for the amount of light available even in static situations, e.g. a dull day. (Again, see article above). The most power you can get out of your panel is when you draw the maximum current without sending the voltage below somewhere around 4 volts, on your panel, and vary this current draw to ensure the voltage hovers around this 'sweet spot'. Adafruit achieve this using the Microchip MCP73871 in a product USB / DC / Solar Lithium Ion/Polymer charger [Rev C] : ID 390 : $17.50 : Adafruit Industries, Unique & fun DIY electronics and kits. (I have no affiliation with Adafruit. There is a similar product on Sparkfun too).
The voltage output by the unit may still be below 5 volts but you could boost this with Crossroads suggestion (or ones like the two buck/boost units that I suggested above), attaching this to the load terminal of the solar regulator unit. You don't have to have a LiPo connected to the regulator unit to do this.
This way you know the setup will work in sub optimal lighting and will optimise your charging for any conditions.
Needless to say, you can't expect to draw more power out of the setup than the the panel can provide. The above will optimise your solar charging but cannot produce something for nothing.
So I visited jremington's link (Thanks!) about data line voltages, and it proved very useful.
I bought resistors for this circuit -
and it's actually working fine.
The adafruit page mentioned that the circuit I'm using should only accept about 500mA, and this seems right, as it's charging near half speed. I'm thinking about looking into this circuit -
which might give higher current.
Also, I replaced the two separate diodes with one main diode, raising the unloaded circuit to 5.8 volts, so the solar panels appear to be working as advertised.
My question now is - with the current circuit, the + and - leads of the charger are connected, albeit through resistors. Will this damage the panels when not connected to a device?
