I'm still new to this programming world. Can someone please help me. I'm working on this project for solar panel dual axiswhich run in two mode(Manual/Auto).Maunual mode will be control by using Labview. I've installed 4 LDR to act as a sensor on all the 4 corners of the panel. My solar panel keep rotating anticlockwise direction after getting instruction from the attach coding coding after uploading it in the Arduino board(Arduino Pro Mini 5v,16Mhz ATmega328).
I would like to know if it's the coding or the hardware problem?
Can you post a picture of your panel and LDR placement please.
It seems odd to place the LDRs at the corners of the PV instead of together with shadow boards between them.
Do you have shade tubes on them so they only see light from directly in front of them?
