Hello community, I have a question regarding a battery charged through a small solar panel. Here is what I want to achieve. First of all, I am not using an Arduino since this project doesn't require a microprocessor, so I apologize if this question shouldn't be here.
I want to power a small dc motor through a 3.7v 380 mah lipo battery. At the same time, one or two 5v 30 mah small solar panels would recharge the battery while not in use.
So far, I have this hardware:
Solar panel
https://www.amazon.com/dp/B06XTX3L6L?ref_=cm_sw_r_cp_ud_dp_874T1QTEYJVA2JGP5HRF
Charging controller
Lipo battery
The motor
I was thinking maybe to add a step-up booster for when there is not enough light to charge the battery. If so, is there any you would recommend?
The motor will be activated with the push of a button, and the whole setup will have a switch to turn it on or off. The battery will still be able to charge when the device is off.
My question is regarding the use of a step-up booster. Is it really necessary in order to get enough power going through the charger module?
Would that be enough with one panel or should I add an extra one?
Thank you so much for your time.
