Hi everybody,
first of all I would like to apologize for the, probably very basic and stupid questions for you, but I'm not an electronic expert..
I'm implementing my project using an Arduino Mega 2560 (I need more pins.. this is the most important reason that it drives the Arduino choice)
I'll put my project in an external environment without the electricity source. For this reason my idea is to use a battery with a solar panel as power input to charge the battery.
I also applied some low-power techniques in order to reduce energy consumption as much as possible.
Regarding the solar panel and battery connections I purchased this Arduino Solar Shield.
And here I'm a bit (a lot) confused about the choice of the battery and the solar panel(s) to be purchased.
First of all, my idea is to use multiple (2 or 4) solar panels in order to exploit as much as possible the solar light (multiple positions) but I'm not able (I'm not sure) about the solar panel selection to purchase.
Considering that the maximum current that the solar shield could be delivered is 700mA can I use 4 solar panels like this
(applying also 4 applying 4 diodes to avoid reverse current)?
About this the possible number or size of the solar panels Do I need to consider the amount of th Current at Peak Power?
For example, using 4 solar panels with 170mA as Current at Peak Power, 4*170 = 680 that it's > of the current of the solar shield.
So, is this wrong? Do I reduce the amount of the panels or do I use a different panel?
About the Solar input voltage it's 4.8~6V.
These are the specifications about the solar panel:
- Dimensions: 100x80x2.5(±0.2) mm
- Typical voltage: 5.5V
- Typical current: 170mA
- Open-circuit voltage: 8.2 V
- Maximum load voltage: 6.4V
Maximum load voltage, Open-circuit voltage are > Solar input voltage. Is it a risk?
About the lipo battery, can I use a battery 3.7v and about the mAh value as high as possible (for example this https://www.amazon.it/2100mAh-Lithium-Polymer-Replacement-Bluetooth/dp/B095BTSMYH/?th=1 ?)
What about the maximum current value (in this case 5A)? Is it ok?
In case, can you suggest me something else?
