solar tracker with data logginh and playback
I would like to use a; dual axis gambol
DIY 2 axis Brushless Direct Drive Gimbal Controller module 50x50mm+MPU6050
http://www.ebay.com/itm/261206811024?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
To create a solar tracker.
The plan is to log data, then play it back through the solar tracker as to reproduce the movements it made while fallowing the flashlight.
I will also be using the; I2C EEPROM - 256kbit COM-00525 RoHS Compliant , for data logging
It would be great if you had any suggestions.
Sincerely,
Tony L
trappers:
I suggest you go for it - you seem to have a clear idea what you want to achieve and the components you need to achieve it.
Hi Tony
How large is the solar panel you'll be using? Or is the term solar tracker used just to mean you'll be tracking a bright light? Reason for asking is I don't know how much torque that gimbal will give you for turning any decent sized panel. Also, if you're only turning the gimbal toward the point where it receives the most power from the solar panel the additional sensors on that gimbal are probably overkill...but still very cool.
From the logging perspective I've got a few of these EEPROMs myself but found quickly that an SD card has a far greater capacity. So far when the internal EEPROM of the ATmega is insufficient the SD is the next port of call so these have gone unused. Of course it will depend on how many bytes each data point will require, how frequent those data points are recorded and the duration of your recording whether you'll need the extra storage of SD but it's potentially worth considering.
Cheers ! Geoff
trappers:
https://www.sparkfun.com/products/525
Sincerely,
Tony L
I have already use it and i think it is good far me and as well as good for all.
