Solar woater heater and gas heater
Hi I begen a new project and i need help my first project, i have a solar woater heater and a gas woater heater and i can't control the 3 wey valve properly tis is my code :
#include <OneWire.h>
#include <DallasTemperature.h>
int tankmax = 212;
int diff = 15;
int valvemax = 212;
int flowmin = 86;
float werethere = 1.5;
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
byte tanktopThermometer[8] = { 0x28, 0x89, 0xFF, 0x79, 0x97, 0x15, 0x03, 0x33 };
byte collectorThermometer[8] = { 0x28, 0x6B, 0x38, 0x79, 0x97, 0x15, 0x03, 0x07 };
int pump = 12;
int valve = 11;
int pumpstate;
int valvestate;
void setup ()
 //start serial port
 Serial.println ("Solar hot water Differential Controller");
 // Start up the onewire library
 sensors.begin();
// locate devices on the bus
 Serial.print("Locating devices...");
 Serial.print("Found ");
 Serial.print(sensors.getDeviceCount(), DEC);
 Serial.println(" devices.");
 // report parasite power requirements
 Serial.print("Parasite power is: ");
 if (sensors.isParasitePowerMode()) Serial.println("ON");
 else Serial.println("OFF");
 // set the sensor resolution from 9 to 12 bit
 sensors.setResolution(tanktopThermometer, 10);
 sensors.setResolution(collectorThermometer, 10);
 //set pins to output
 pinMode (pump, OUTPUT);
 pinMode (valve, OUTPUT);
float sensorValue (byte deviceAddress[])
float tempC = sensors.getTempC (deviceAddress);
float temp = (DallasTemperature::toFahrenheit(tempC));
return tempC;
void loop ()
 sensors.requestTemperatures();
 float tank = (sensorValue(tanktopThermometer));
 float collector = (sensorValue(collectorThermometer));
 Serial.print ("tank ");
 Serial.println (tank);
 Serial.print ("collector ");
 Serial.println (collector);
 Serial.print ("pump state ");
 Serial.println (pumpstate);
 Serial.println ("");
 Serial.print ("valvestate ");
 Serial.println (valvestate);
 digitalWrite (pump, HIGH);
 static bool pumpOn=false;
if ( pumpOn)
 if (((collector - werethere) < tank ) && (tank >= tankmax) )
   digitalWrite (pump, LOW);
   pumpOn =false;
 if (((collector - diff) > tank ) && ( tank < tankmax ) )
   pumpOn = true;
  if (  ( tank > flowmin ) && ( tank < tankmax )  )
  {digitalWrite (valve, HIGH); valvestate = 0;}
  if (  ( tank < flowmin ) && (tank < tankmax )  )
    {digitalWrite (valve, LOW); valvestate = 1;}
and i need for pin 11 to be low for 30 s and den high for open and pin 10 to be low fur 30s for clouszing the valve and wen resset to put it in a nown pozision
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor. The text editor shows line numbers, identifies matching brackets and allows me to search for things like all instances of a particular variable or function.
Also, please tell us exactly what happens when you run your program and what you want it to do that is different.
Have a look at how millis() is used to manage timing without blocking in Several Things at a Time.
And see Using millis() for timing. A beginners guide if you need more explanation.
...R
